[mapserver-users] Problems with PHP MapScript and Tiles unde WinNT
4.0
Daniel Morissette
morissette at dmsolutions.ca
Wed Dec 19 10:05:32 EST 2001
Peter,
A few notes:
1- Do all the shapefiles in your tiled layer share the exact same set of
attributes? This is very important. All the files in a tiled layer
must have the same attributes and in the same order.
2- You should try this again with the 3.5 release DLL once one becomes
available.
If this problem still happens after this, then if possible send us a
copy of the data and PHP script and exact steps to reproduce and we'll
have a look.
Daniel
Peter Haussl wrote:
> Hi Steve!
> I'm using PHP MapScript 3.5 (php_mapscript_35.dll date 2001-10-15).
> If I use the following Layer in my Mapfile (which works using the CGI)
> LAYER
> NAME Rivers
> TYPE Line
> STATUS default
> DATA l_wl
> TILEINDEX tiles
> # MINSCALE 1000
> # MAXSCALE 150000
> CLASSITEM 'layer'
> LABELITEM 'name'
> LABELMAXSCALE 25000
> CLASS
> EXPRESSION /^q$|^qm$|^qo$|^qw$|^Q$|^QM$|^QO$|^QW$/
> SYMBOL 'circle'
> # MINSIZE 1
> # MAXSIZE 5
> SIZE 4
> COLOR 100 100 255
> END
> END
> The php_mapscript_35.dll produces a Dr. Watson error message.
> The same layer without Tileindex seems to work!
> Is there a special Version working together with tile or is there a Bug?
> Many thx
> Peter
> Greetings from Austria / Europe
