[mapserver-users] mapfile for my problem
Stephen Lime steve.lime at dnr.state.mn.us
Thu Dec 20 11:59:31 EST 2001
The status setting for the scalebar is wrong. Should be STATUS ON/OFF. ON != TRUE. At least at first glance that seems to be the problem.
Since you have no layers defined there is nothing to create a legend from. Futhermore class members in layers MUST have a NAME defined to show up in the legend.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> G Kelley <gk1611 at ship.edu> 12/20/01 10:02AM >>>
Here's the mapfile:
NAME TEST
EXTENT 471127 4751545 489292 4765610
UNITS FEET
SIZE 600 600
SHAPEPATH "/export/home/stu/gk1611/public_html/shapefiles"
INTERLACE OFF
# Start of layers
LAYER
	NAME "Parcels"
	DATA poly
	STATUS DEFAULT
	TYPE POLYGON
	CLASS
		COLOR 73 76 113
		OUTLINECOLOR 0 0 0
	END # end of class object
END # end of layer object
# Start of scalebar
SCALEBAR
  IMAGECOLOR 255 255 255
  LABEL
    COLOR 255 255 255
    SIZE tiny
  END
  STYLE 1
  SIZE 50 2
  COLOR 255 255 255
  UNITS FEET
  INTERVALS 1
  TRANSPARENT TRUE
  STATUS TRUE
END
# Start of legend
LEGEND
  STATUS ON
  KEYSIZE 18 12
  LABEL
    TYPE BITMAP
    SIZE MEDIUM
    COLOR 0 0 89
  END
END # end of legend object
WEB
	LOG "/export/home/stu/gk1611/public_html/output/mapserver.log"
	IMAGEPATH "/export/home/stu/gk1611/public_html/output/"
	IMAGEURL "/~gk1611/output/"
	TEMPLATE "../testpoly/newtest.html"
END # end of web object
END # end of map file
Thanks,
Gregg
