[mapserver-users] LD_LIBRARY_PATH
Don Silvia
don at zeroazimuth.com
Mon Dec 24 14:10:20 EST 2001
Those directives belong in httpd.conf. Make sure they come after any
LoadModule and AddModule directives.
Don Silvia
> -----Original Message-----
> From: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu]On Behalf Of
> XSun at odu.edu
> Sent: Monday, December 24, 2001 10:30 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] LD_LIBRARY_PATH
> Hello Steve and all other friends,
> After read all the articles in the list about the LD_LIBRARY_PATH problem.
> I am still puzzled with one problem. which file should I modify
> to add the
> following lines.
> SetEnv LD_LIBRARY_PATH "/usr/local/lib"
> PassEnv LD_LIBRARY_PATH
> I tried to add to .cshrc file. But It can not acknowledge "PassENV"
> command.
> I tried to add to httpd.conf. "SetEnv" is not valid command. By
> the way ,
> my apache server is now a binary installation. I download the source code
> , and read the source file of mod_env.c , But I didnot know if I should
> modify it and how to modify?
> Which files should I modify? .cshrc ? httpd.conf? mod_env.c?
> Can someone give me some hint about it?
> Thanks a lot.
> Have a great holiday and merry christmas to all in the lists!
> XSun
