scale and query problems
Robert Ofarrell
s371538 at student.uq.edu.au
Sun Feb 4 20:36:44 EST 2001
Daniel,
A few weeks ago I asked this question, but really didn't get around to
looking into the problem furthur until now. However I am still have the
same problem as before. I am sure that my layers are setup properly and
have included the mapfile that I am using below this message.
Your suggestions would be greatly appreciated.
Robert
> A couple of problems that I have run into when using MapScript with
PHP3.
> 1. When doing a query on a map with multiple layers, the result of a
> msqueryUsingPoint() only returns the shapes in the first two layers and
> seems to ignore the other layers on the map. I have a nice tolerance so
> that all the layers have some shape where I click but only the first two
> layers respond.
Robert,
This probably has more to do with your .map layers setup than with
MapScript itself. Are all the layers you want to query with STATUS=ON,
and do they all contain a QUERY object?
We've used queries with multiple layers before and I don't remember
noticing a problem... but a bug is always possible. If you're sure that
your layers are setup properly, then please send me your .map file and
I'll try to reproduce/fix the problem.
// Map File
NAME NSW
SIZE 300 300
SYMBOLSET symbols/symbols.sym
EXTENT 150.000000 -34.000000 152.000000 -32.000000
UNITS KILOMETERS
SHAPEPATH data/
IMAGECOLOR 238 238 255
# Web Object
WEB
MINSCALE 100
MAXSCALE 100000
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END #Web
# Legend Object
LEGEND
STATUS OFF
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END #Label
END #Legend
# ScaleBar Object
SCALEBAR
STATUS ON
SIZE 150 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
INTERVALS 5
UNITS KILOMETERS
LABEL
COLOR 0 0 0
SIZE SMALL
END
END #Scalebar
# Reference Map
REFERENCE
STATUS ON
COLOR -1 -1 -1
IMAGE "graphics/refmap.gif"
OUTLINECOLOR 0 0 0
SIZE 100 100
END #Reference
# QueryMap Object
QUERYMAP
COLOR 192 192 192
STYLE HILITE
END #QueryMap
# Layer Objects
# Layer: "nsw1_pal2_poly"
LAYER
NAME "nsw1_pal2_poly"
DESCRIPTION "nsw1_pal2_poly"
TYPE POLYGON
STATUS ON
DATA "nsw1_pal2_poly"
CLASSITEM 'NSW1P_ID'
CLASSITEM 'AREA'
CLASSITEM 'PERIMETER'
CLASSITEM 'NSW1_PAL2_'
CLASSITEM 'IDENT'
CLASSITEM 'NAME'
CLASSITEM 'RES_TYPE'
CLASSITEM 'RES_AREA'
CLASSITEM 'STATE'
CLASSITEM 'AUTHORITY'
CLASSITEM 'RES_NUMBER'
CLASSITEM 'PROCLAIMED'
CLASSITEM 'LATEST_GAZ'
CLASSITEM 'SOURCE'
CLASSITEM 'REVISED'
CLASSITEM 'FEATURE'
CLASS
EXPRESSION (1 eq 0)
COLOR 192 192 192
OUTLINECOLOR 0 0 0
LABEL
FORCE true
PARTIALS true
POSITION auto
SIZE small
COLOR 255 255 255
OUTLINECOLOR 0 0 0
END #Label
END #Class
CLASS
EXPRESSION (1 eq 1)
COLOR 120 170 69
OUTLINECOLOR 0 0 0
END #Class
QUERYITEM 'NSW1P_ID'
QUERYITEM 'AREA'
QUERYITEM 'PERIMETER'
QUERYITEM 'NSW1_PAL2_'
QUERYITEM 'IDENT'
QUERYITEM 'NAME'
QUERYITEM 'RES_TYPE'
QUERYITEM 'RES_AREA'
QUERYITEM 'STATE'
QUERYITEM 'AUTHORITY'
QUERYITEM 'RES_NUMBER'
QUERYITEM 'PROCLAIMED'
QUERYITEM 'LATEST_GAZ'
QUERYITEM 'SOURCE'
QUERYITEM 'REVISED'
QUERYITEM 'FEATURE'
TOLERANCE 0
QUERY
EXPRESSION (1 eq 1)
TEMPLATE ""
END #Query
END #Layer
# Layer: "nsw1_pal2_line"
LAYER
NAME "nsw1_pal2_line"
DESCRIPTION "nsw1_pal2_line"
TYPE LINE
STATUS ON
DATA "nsw1_pal2_line"
CLASSITEM 'NSW_ID'
CLASSITEM 'FNODE_'
CLASSITEM 'TNODE_'
CLASSITEM 'LPOLY_'
CLASSITEM 'RPOLY_'
CLASSITEM 'LENGTH'
CLASSITEM 'FEATURE'
CLASSITEM 'STATE'
CLASS
EXPRESSION (1 eq 0)
COLOR 192 192 192
OUTLINECOLOR 0 0 0
LABEL
FORCE true
PARTIALS true
POSITION auto
SIZE small
COLOR 255 255 255
OUTLINECOLOR 0 0 0
END #Label
END #Class
CLASS
EXPRESSION (1 eq 1)
COLOR 70 120 69
OUTLINECOLOR 0 0 0
END #Class
QUERYITEM 'NSW_ID'
QUERYITEM 'FNODE_'
QUERYITEM 'TNODE_'
QUERYITEM 'LPOLY_'
QUERYITEM 'RPOLY_'
QUERYITEM 'LENGTH'
QUERYITEM 'FEATURE'
QUERYITEM 'STATE'
TOLERANCE 0
QUERY
EXPRESSION (1 eq 1)
TEMPLATE ""
END #Query
END #Layer
# Layer: "nsw2_pal2_poly"
LAYER
NAME "nsw2_pal2_poly"
DESCRIPTION "nsw2_pal2_poly"
TYPE POLYGON
STATUS ON
DATA "nsw2_pal2_poly"
CLASSITEM 'NSW_ID'
CLASSITEM 'AREA'
CLASSITEM 'NSW2_PAL2_'
CLASSITEM 'IDENT'
CLASSITEM 'NAME'
CLASSITEM 'STATE'
CLASSITEM 'SOURCE'
CLASSITEM 'REVISED'
CLASSITEM 'FEATURE'
CLASS
EXPRESSION (1 eq 0)
COLOR 192 192 192
OUTLINECOLOR 0 0 0
LABEL
FORCE true
PARTIALS true
POSITION auto
SIZE small
COLOR 255 255 255
OUTLINECOLOR 0 0 0
END #Label
END #Class
CLASS
EXPRESSION (1 eq 1)
COLOR 200 0 0
OUTLINECOLOR 0 0 0
END #Class
QUERYITEM 'NSW_ID'
QUERYITEM 'AREA'
QUERYITEM 'NSW2_PAL2_'
QUERYITEM 'IDENT'
QUERYITEM 'NAME'
QUERYITEM 'STATE'
QUERYITEM 'SOURCE'
QUERYITEM 'REVISED'
QUERYITEM 'FEATURE'
TOLERANCE 0
QUERY
EXPRESSION (1 eq 1)
TEMPLATE ""
END #Query
END #Layer
# Layer: "nsw2_pal2_line"
LAYER
NAME "nsw2_pal2_line"
DESCRIPTION "nsw2_pal2_line"
TYPE LINE
STATUS ON
DATA "nsw2_pal2_line"
CLASSITEM 'NSW_ID'
CLASSITEM 'FNODE_'
CLASSITEM 'TNODE_'
CLASSITEM 'LPOLY_'
CLASSITEM 'RPOLY_'
CLASSITEM 'LENGTH'
CLASSITEM 'FEATURE'
CLASSITEM 'STATE'
CLASS
EXPRESSION (1 eq 0)
COLOR 192 192 192
OUTLINECOLOR 0 0 0
LABEL
FORCE true
PARTIALS true
POSITION auto
SIZE small
COLOR 255 255 255
OUTLINECOLOR 0 0 0
END #Label
END #Class
CLASS
EXPRESSION (1 eq 1)
COLOR 0 0 0
OUTLINECOLOR 0 0 0
END #Class
QUERYITEM 'NSW_ID'
QUERYITEM 'FNODE_'
QUERYITEM 'TNODE_'
QUERYITEM 'LPOLY_'
QUERYITEM 'RPOLY_'
QUERYITEM 'LENGTH'
QUERYITEM 'FEATURE'
QUERYITEM 'STATE'
TOLERANCE 0
QUERY
EXPRESSION (1 eq 1)
TEMPLATE ""
END #Query
END #Layer
# Layer: "nsw_pnt2_point"
LAYER
NAME "nsw_pnt2_point"
DESCRIPTION "nsw_pnt2_point"
TYPE POINT
STATUS ON
DATA "nsw_pnt2_point"
CLASSITEM 'NSW_ID'
CLASSITEM 'AREA'
CLASSITEM 'NSW_PNT2_'
CLASSITEM 'NSW_PNT2_I'
CLASSITEM 'IDENT'
CLASSITEM 'NAME'
CLASSITEM 'STATE'
CLASSITEM 'SOURCE'
CLASSITEM 'REVISED'
CLASSITEM 'FEATURE'
CLASS
EXPRESSION (1 eq 0)
COLOR 192 192 192
OUTLINECOLOR 0 0 0
LABEL
FORCE true
PARTIALS true
POSITION auto
SIZE small
COLOR 255 255 255
OUTLINECOLOR 0 0 0
END #Label
END #Class
CLASS
EXPRESSION (1 eq 1)
SYMBOL 4
SIZE 5
COLOR 0 0 255
END #Class
QUERYITEM 'NSW_ID'
QUERYITEM 'AREA'
QUERYITEM 'NSW_PNT2_'
QUERYITEM 'NSW_PNT2_I'
QUERYITEM 'IDENT'
QUERYITEM 'NAME'
QUERYITEM 'STATE'
QUERYITEM 'SOURCE'
QUERYITEM 'REVISED'
QUERYITEM 'FEATURE'
TOLERANCE 0
QUERY
EXPRESSION (1 eq 1)
TEMPLATE ""
END #Query
END #Layer
END #MapFile
