Mapfile REGEXPs (was Re: point file filter)
Kieran J. Ames
kames at keyspanenergy.com
Tue Feb 6 09:26:08 EST 2001
Maybe I could add my own question here...
I'd like to try using REGEXPs in a mapfile to do the same thing. I have a list of
hospital facilities where I'm enumerating the total number of beds. I want to render
the data based on the number of beds. I tried evaluating the number of TOTAL_BEDS,
but can only get it to work as follows. What I'd like to do is say something like:
EXPRESSION/> 400/
as opposed to
EXPRESSION /[4-9][1-9][0-9]/
Thanks,
Kieran
snippet follows...
CLASSITEM TOTAL_BEDS
CLASS
NAME 'Greater than 401 Beds'
SIZE 5
COLOR 0 0 0
SYMBOL 1
END
CLASS
NAME '250-400 Beds'
SIZE 4
EXPRESSION /^[2-3][5-9][0-9]$|^3[0-9][0-9]$/
COLOR 0 0 255
SYMBOL 1
END # CLASS
Stephen Lime wrote:
> You can use dynamic expressions to do that. Let's say you have a mapfile with
> a point layer called "mypoints" with a single class. You can set up a select list
> to set the expression for that class:
> <select name="map_mypoints_class_expression" single>
> <option value="expression"> option 1</option>
> <option value="expression"> option 2</option>
> </select>
> The expressions can be any valid MapServer (i.e. string, logical or regular)
> expression. Syntax of the expression is identical to that entered in a map
> file.
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> <Alexspringer at aol.com> 02/03/01 05:06PM >>>
> Using the mapserver cgi, I have a point file in use. I would like to add a
> select [drop down box] that has values for a filter to be applied to one
> field in the point file dbf so that only those records with the field value
> equal to that filter display. Does anyone have an example of the .map and
> .htm that can demonstrate how this is implemented?
> Thank you.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010206/244a7024/attachment.html
