Problems with ms_newFeatureObj in PHP3 MapScript
Martin Lowry m.lowry at medschool.hull.ac.uk
Thu Feb 15 05:19:25 EST 2001
Hello Daniel,
Many thanks for your reply.  I've been using MS 3.3.011 so no wonder I
was having problems!
I will immediately upgrade to 3.4.
> Which version of PHP MapScript are you using?
> I think ms_NewFeatureObj() has been removed after the 3.3.011 release
> and it may well have been broken in version 3.3.011.
> I suggest that you get version 3.4 (it is much more stable anyways) and
> use layerObj's addFeature(shapeObj shape) method which replaced the
> ms_NewFeatureObj().
Cheers!
Martin Lowry                            Voice: +44 (0)1482 674075
                               Fax:   +44 (0)1482 320137
                      Email: mailto:m.lowry at medschool.hull.ac.uk
   WWW  : http://www.med-phys.hull.ac.uk/~martin/Lobivia
