Creating shape file for tiled images
Larry Nolan lrn at zeppo.geosurv.gov.nf.ca
Mon Feb 19 14:04:10 EST 2001
Don,
   I have a tiled index of NTS mapsheets (similar to the quads in the US)
the attached file
contains the index. I then use the table columns to select each of my data
themes. I have a dummy
shapefile for map tiles which do not have a file for that layer. The dummy
needs to have extents which cover the whole map area.
LAYER
  NAME "lakes"
  TYPE POLYGON
  STATUS DEFAULT
  MINSCALE 150001
  MAXSCALE 600000
  TILEINDEX NTS_NFLD_250
  TILEITEM WATERP
    CLASSITEM DESCRIPTIO
     CLASS
      EXPRESSION ('[FEATURE]' eq 'WABOFW' OR '[FEATURE]' eq 'WARI' OR
'[FEATURE]' eq 'WAFL' OR '[FEATURE]' eq 'WAFA')
    COLOR  255 255 255
    OUTLINECOLOR 142 205 247
  END
END # Layer
LAYER
  NAME "Water"
  TYPE LINE
  STATUS DEFAULT
  TILEITEM WATER
  MINSCALE 150001
  MAXSCALE 600000
     CLASS
      EXPRESSION ('[DESCRIPTIO]' ne 'Virtual Line')
      SYMBOL 0
      OUTLINECOLOR 0 0 255
     COLOR  0 0 255
   END # CLASS
END # Layer
LAYER
  NAME "vegetation"
  TYPE POLYGON
  STATUS DEFAULT
  MINSCALE 100
  MAXSCALE 600000
  TILEITEM VEGETATP
     CLASS
     EXPRESSION ('[DESCRIPTIO]' eq 'Wooded Area')
    COLOR  125 242 187
    OUTLINECOLOR 125 242 187
  END
END # Layer
Larry Nolan
Project Geologist - GIS
Geological Survey of Newfoundland
709-729-2168
----- Original Message -----
From: "Don Silvia" <don at dlsilvia.ne.mediaone.net>
To: "Michael Schulz" <mschulz at webgis.de>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, February 19, 2001 1:39 PM
Subject: Re: Creating shape file for tiled images
> Michael,
> Thanks, I'd be interested in any way to automate the process.  I've never
> created an image catalog in ArcView, and the help documentation makes me
> think that it's pretty labor intensive.
> I've started working on creating the shapefile using the Shape perl
module,
> which is a worthwhile exercise for me.  But I can't help thinking there
has
> to be an easier way.
> I know others have done this, and I'd appreciate hearing their solutions
> too.  An example of a tileindex shapefile would be really helpful.
> Thanks,
> Don Silvia
> At 10:22 AM Monday 2/19/2001, Michael Schulz wrote:
> >Hi Don and List,
> >since i also have to incorporate tiled image data, i was starting to
write a
> >small Arcview avenue script that would create a mapserver tileindex
shapefile
> >from an imgcat. I wanted to post it later on, when it's finished, but if
> >anyone
> >wants the first draft, please contact me.
> >Michael
> >Don Silvia schrieb:
> > > Hi,
> > > I'm trying to use tiled images with mapserver and I've seen some
previous
> > > posts on this list that refer to tileindex.  I get the basic idea of
what I
> > > need to do, but how can I create an index shape file for my images?
> > > Thanks,
> > > Don Silvia
> >Michael Schulz                                in medias res
> >Dipl.-Geologe                              Gesellschaft für
> >                                 Informationstechnologie mbH
> >                              Sautierstr. 38, 79104 Freiburg
> >                                      0761 55695-95 (Fax 96)
> >mschulz at webgis.de                             www.webgis.de
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010219/3848af14/NTS_NFLD_250.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010219/3848af14/NTS_NFLD_250-0001.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010219/3848af14/NTS_NFLD_250-0002.obj
