Adding color access to mapscript
Stephen Lime steve.lime at dnr.state.mn.us
Thu Feb 22 11:17:50 EST 2001
Ok, it's a kludge but should work. Untar the attached file someplace and move map.h
to the main source directory, mapscript.i to the mapscript directory and the other two
files to mapscript/perl. Then rebuild as normal. That should expose the palette to
mapscript and add a method to get at colors. Usage is:
  $color = $map->getColor($i);
  print "Color is: ". $color->{red} ." ". $color->{green} ." ". $color->{blue} ."\n";
  print "Number of colors is: ". $map->{palette}->{numcolors} ."\n";
Note that the palette only contains colors as assigned to features. No raster color
information is present.
Only use this code if you *really* need the functionallity.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
