PROJ4, PHP and projection of a single point (fwd)
teb
teb at mallit.fr.umn.edu
Thu Feb 22 11:47:06 EST 2001
------------- Begin Forwarded Message -------------
From: "Stein Runar Bergheim" <runar at bergheim.dk>
To: <mapserver-info at lists.gis.umn.edu>
Subject: PROJ4, PHP and projection of a single point
Date: Thu, 22 Feb 2001 10:05:37 +0100
MIME-Version: 1.0
X-Priority: 3
X-MSMail-Priority: Normal
X-MimeOLE: Produced By Microsoft MimeOLE V5.00.2919.6700
I am retreiving a set of points from a database, and am drawing
them onto the image object of a map via a layer that is projected
from lat/long to WGS84 coordinates.
This is easy going, my problem occurs when I want to collect a
pair of coordinates from the map, perform an inverse projection
of them and use them to query the database...
Is this possible or should I try some alternate approach...
Regards
SRB
------------- End Forwarded Message -------------
