Can tiled set of shapefiles be re-projected on the fly ?
Herbie Freytag HFreytag at dlwc.nsw.gov.au
Tue Feb 27 02:39:23 EST 2001
Displaying a tiled dataset works on our mapserv3.3 installation, as does reprojection of untiled datasets.
However, reprojection of tiled dataset does not work.... configuration error or not yet supported ?
Herbie
Herbie Freytag ICMISS Support
Tel: +61 2 9895 7335    Fax: +61 2 9895 7834
hfreytag at dlwc.nsw.gov.au
Department of Land & Water Conservation
Level 4, 10 Valentine Ave, Parramatta
Sydney,  Australia
WARNING: This message is intended for the addressee named and may contain confidential/privileged information. If you are not the intended recipient, please delete it and notify the sender. Views expressed in this messages are those of the individual sender, and are not necessarily the views of the NSW Department of Land and Water Conservation. You should scan any attached files for viruses.
