query by expression
Stephen Lime steve.lime at dnr.state.mn.us
Mon Jan 29 22:35:41 EST 2001
Yes, query of tiled data (and SDE and OGR) will be in
the next release. Some major changes were made to
facilitate queries across the board which is why it's
taking so long. I'm testing shapefiles and tiled
shapefiles now and should be commiting the code this
week. Then SDE and OGR still need to be brought up to
date.
Steve
>>> "Joel Anderson" <joela at joelhq.com> 01/29/01 19:28 PM >>>
Hello All,
I haven't been very diligent about keeping up on this, so I'll just ask:
speaking of the next release, is querying tiled data going to be available?
That would be really great if true!
Thanks
Joel
----- Original Message -----
From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
To: <morissette at dmsolutions.ca>; <s371538 at student.uq.edu.au>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, January 29, 2001 1:14 PM
Subject: Re: query by expression
> I wanted to add that this is what itemquery is turning into in the next
release. Dan's
> suggestion is a good workaround for the moment.
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> Daniel Morissette <morissette at dmsolutions.ca> 01/29/01 01:11PM >>>
> Robert Ofarrell wrote:
> > Daniel,
> > Is it possible to query by expression and get the shapes returned by
such
> > a query?
> > Something to the effect of $map->queryUsingExpression();
> > Robert O'Farrell
> > University of Queensland, Brisbane, Australia
> Robert,
> There is no queryUsingExpression() call... but you might be able to
> achieve the same result if you set the expression in the query object of
> the layer, and then use queryUsingRect() with a rectangle the size of
> th map.  I've never done it, but that should work.
>  Daniel Morissette                morissette at dmsolutions.ca
>                  http://www.dmsolutions.ca/
>   Don't put for tomorrow what you can do today, because if
>       you enjoy it today you can do it again tomorrow.
