[mapserver-users] compiling under windows makefile vc syntax error ?
David Armstrong david.armstrong at ntlworld.com
Mon Jul 2 12:50:01 EDT 2001
i am getting the following error when running the makefile.vc under windows
2k with visual studio  nmake command
copy ./gdal-1.1.4/gdal.pdb .
The syntax of the command is incorrect.
the following is the offending lines in the makefile can anyone put some
light on this
$(MS_LIB): $(MS_OBJS)
copy $(GDAL_DIR)/gdal.pdb .
lib /out:$(MS_LIB) $(MS_OBJS)
i can overcome this manually by copying the file across and commenting out
the copy command , but i would like to correct this
Regards to All
Dave
