[mapserver-users] compiling under windows makefile vc syntaxerror ?
Assefa Yewondwossen assefa at dmsolutions.ca
Mon Jul 2 17:09:41 EDT 2001
I just updated the CVS version with the modifications you suggested.
Bye
"Pericles S. Nacionales" wrote:
> Dave,
> All I did for that one is switch the "/" to "\" on the "copy
> ..." line.  This still won't work unless you also switch the slashes on
> the GDAL_DIR somewhere else on that Makefile.  The problem with this is
> that the DOS (or Windows) copy command uses the backslash (\) in
> paths.  Nmake itself don't have that problem but system commands do.  For
> uniformity's sake, you might want to switch all the path slashes to
> backslash.
> Example Makefile.vc:
> ...(stuff omitted)
> GDAL_DIR= ..\..\gdal
> OGR=-DUSE_OGR
> OGR_LIB = $(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts.lib
> $(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts_sup.lib $(GDAL_DIR)/ogr/ogr.lib
> $(GDAL_DIR)/ogr/../port/cpl.lib
> OGR_INC = -I$(GDAL_DIR)/ogr/ogrsf_frmts -I$(GDAL_DIR)/ogr
> -I$(GDAL_DIR)/port
> ...(more stuff omitted)
> $(MS_LIB):      $(MS_OBJS)
>         copy $(GDAL_DIR)\gdal.pdb .
>         lib /out:$(MS_LIB) $(MS_OBJS)
> ...(the rest of the stuff omitted)
> Good luck!
> -Perry
> On Mon, 2 Jul 2001, David Armstrong wrote:
> > i am getting the following error when running the makefile.vc under windows
> > 2k with visual studio  nmake command
> > copy ./gdal-1.1.4/gdal.pdb .
> > The syntax of the command is incorrect.
> > the following is the offending lines in the makefile can anyone put some
> > light on this
> > copy $(GDAL_DIR)/gdal.pdb .
> > i can overcome this manually by copying the file across and commenting out
> > the copy command , but i would like to correct this
> > Regards to All
> > Dave
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056
