[mapserver-users] Polyline problem
Vinko Vrsalovic B. v at w.cl
Thu Jul 19 22:22:36 EDT 2001
Hi again.
I'm having a problem with polyline shapes.
mapserv says:
msDrawShapefileLayer(): General error message. POLYGON layers must be
POLYGON shapefiles.
As you can see in the map file, the layer is declared as POLYLINE not
a POLYGON, so I don't understand why it doesn't work as expected.
The shape is a polyline made with ArcView. If I change the layer to be a
LINE, mapserv displays a dot, unzoomable.
Here's my map file:
# Start of map file
NAME BUSES
SIZE 600 600
SYMBOLSET ./symbols/symbols.sym
EXTENT -71.812301 -33.413659 -71.18889 -33.04636
UNITS METERS
SHAPEPATH "buses"
IMAGECOLOR 255 255 255
PROJECTION
 "proj=utm"
 "ellps=GRS80"
 "zone=19"
 "south"
 "no_defs"
END
# Start of web interface definition
WEB
  HEADER buses_h.html
  TEMPLATE buses.html
  FOOTER buses_f.html
  MINSCALE 1000
  MAXSCALE 1550000
  IMAGEPATH "/var/www/html/ms_demo/tmp/"
  IMAGEURL "/tmp/"
  LOG "buses.log"
END
# Start of scalebar
SCALEBAR
	[yadda yadda yadda]
END
# Start of layer definitions
LAYER
    NAME r_bus5
    TYPE POLYLINE
    STATUS DEFAULT
    DATA r_bus5
    CLASS
        COLOR 100 150 54
    END
END
END # Map File
V. <v at w.cl>
