[mapserver-users] extend command unit
Stephen Lime
steve.lime at dnr.state.mn.us
Fri Jul 27 14:50:49 EDT 2001
It's whatever the UNITS parameters is set to in the mapfile and should match
the output projection system. The CGI version when compiled with proj.4 will do
some automatic recognition of lat/lon coordinates and do the projection for
you, but otherwise extents are always taken as mentioned above.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Chan B. Huynh" <chuynh at ideorlando.org> 07/27/01 12:56PM >>>
Hi there,
What is the unit of the 5-digit minx,maxx,miny,maxy for EXTENT command in
the Map Object?
I thought that should be latitude and longitude???
Thanks for your help.
-chan
DA Intern, STRICOM
Orlando,FL
