[mapserver-users] msDrawRaster TileIndex TileItem Location HELP!
Daniel Morissette
morissette at dmsolutions.ca
Tue Jul 31 15:14:23 EDT 2001
"Hankley, Chip" wrote:
> Richard and I are having the same problem I think...
> I'm beginning to think that on NT, your data HAS to be on a local drive....
It's the first time we hear of this kind of problem AFAIK.
Are you (both) using MapScript, or the MapServer CGI? And if you're
using PHP MapScript then with which version of PHP is it?
Also, are you both running IIS/PWS or did one of you try with Apache?
> Lowell wrote:
> >You might try dumping a simple shapefile over on the share and adding it
> as
> >a layer in your .map file. Just to see if things on that level work.
> I tried this yesterday and got the same results. I used a map file with one
> simple polygon layer. Did it local, worked fine, on a share, didnt' work.
Did you try on a local disk but different from the disk where the map
file lives, e.g.
- place .map file under c:
- place data files on D: (local HD)
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
