[mapserver-users] msDrawRaster TileIndex TileItem Location HE LP!
Puneet Kishor pkishor at GeoAnalytics.com
Tue Jul 31 16:24:23 EDT 2001
Chip, Richard,
Fwiw, here's what I know...
I can confirm what you have experienced... putting data on a mapped drive or
UNC named drive causes Mapserver to choke (I was using Win2k). Copying all
the data to the c: drive (where Mapserver is installed) made good.
IIS/PWS use an account called IUSR_<computername>. So, if you computer is
called mapper, an account called IUSR_mapper is automatically created, and a
random password is generated for it. This insures that anyone hitting the
webserver is able to view the website.
IIS service itself logs on as a local system account.
Look forward to what you guys figure out, because it does have ramifications
on how distributed mapplication is deployed.
pk/
Puneet Kishor
pkishor at geoanalytics.com
www.geoanalytics.com
GeoAnalyics, Inc.
1716 Fordem Ave
Madison WI 53704
> -----Original Message-----
> From: Hankley, Chip [mailto:Chip.Hankley at GASAI.Com]
> Sent: Tuesday, July 31, 2001 12:54 PM
> To: 'Richard Greenwood'; mapserver-users at lists.gis.umn.edu
> Subject: RE: [mapserver-users] msDrawRaster TileIndex
> TileItem Location
> HE LP!
> Richard and I are having the same problem I think...
> I'm beginning to think that on NT, your data HAS to be on a
> local drive....
> Lowell wrote:
>  >You might try dumping a simple shapefile over on the share
> and adding it
> as
>  >a layer in your .map file.  Just to see if things on that
> level work.
> I tried this yesterday and got the same results. I used a map
> file with one
> simple polygon layer. Did it local, worked fine, on a share,
> didnt' work.
>  >Have you tried blowing open the privs just to see if that fixes it?
> This is possible, does anyone know what USER IIS or PWS acts
> as on NT? Does
> it take on the credentials of whoever is logged in, or is it
> something more
> obsure, like %SYSTEM?
> Man, if anyone knows the definitive answer to this, please
> speak up! This
> has some significant ramifications for how I deploy some
> applications, and
> I'm totally stuck.
> Chip Hankley
