[mapserver-users] Mapscript Perl examples - XBase.pm
Don Silvia don at dlsilvia.ne.mediaone.net
Tue May 8 18:17:41 EDT 2001
Oops, sorry about that.  Now I remember installing the wrong one first, so
I should have remembered this.  The correct module can be downloaded from
http://theoryx5.uwinnipeg.ca/scripts/CPAN/authors/id/J/JA/JANPAZ/DBD-XBase-0.173.tar.gz
Don Silvia
At 02:04 PM Tuesday 5/8/2001, Stephen Lime wrote:
>There are two modules Xbase and XBase. The scripts I wrote use the latter.
>Steve
>Stephen Lime
>Internet Applications Analyst
>Minnesota DNR
>500 Lafayette Road
>St. Paul, MN 55155
>651-297-2937
> >>> Don Silvia <don at dlsilvia.ne.mediaone.net> 05/07/01 05:34PM >>>
>Janet,
>You can download the module from
>http://theoryx5.uwinnipeg.ca/scripts/CPAN/authors/id/P/PR/PRATP/Xbase-1.07.tar.gz
>.  See http://theoryx5.uwinnipeg.ca/CPAN/cpan-search.html for a good CPAN
>search engine.
>To build on NT, you'll need to have a make utility, and some modules
>require a C compiler.  You'll already have nmake if you have Visual C++
>installed.
>Don Silvia
>At 10:24 AM Monday 5/7/2001, Janet Ciavarelli wrote:
> >Well, I finally got mapscript compiled and installed into Active X Perl on
> >a WinNT system. Whew! Now, when I go to run the shpinfo.pl, I get an error
> >message cause it can't find XBase.pm I searched my whole system for
> >XBase.pm and it's nowhere to be found. Where do I get XBase.pm from?
> >Anyone know?
> >Janet.
