[mapserver-users] Mapscript Perl examples - XBase.pm
Chris Stuber imap at chesapeake.net
Tue May 8 23:25:36 EDT 2001
On a windows machine w/ActivePerl, you can
just do the following:
C:\> ppm install XBase
and that's it.  It is one of the ActiveState installable modules.
I had sent this directly to Janet when the message was posted
and forgot to cc the list.
Regards,
Chris Stuber (mapsurfer)
Don Silvia wrote:
> Oops, sorry about that.  Now I remember installing the wrong one first, so
> I should have remembered this.  The correct module can be downloaded from
> http://theoryx5.uwinnipeg.ca/scripts/CPAN/authors/id/J/JA/JANPAZ/DBD-XBase-0.173.tar.gz
> Don Silvia
> At 02:04 PM Tuesday 5/8/2001, Stephen Lime wrote:
> >There are two modules Xbase and XBase. The scripts I wrote use the latter.
> >Steve
> >Stephen Lime
> >Internet Applications Analyst
> >Minnesota DNR
> >500 Lafayette Road
> >St. Paul, MN 55155
> >651-297-2937
> > >>> Don Silvia <don at dlsilvia.ne.mediaone.net> 05/07/01 05:34PM >>>
> >Janet,
> >You can download the module from
> >http://theoryx5.uwinnipeg.ca/scripts/CPAN/authors/id/P/PR/PRATP/Xbase-1.07.tar.gz
> >.  See http://theoryx5.uwinnipeg.ca/CPAN/cpan-search.html for a good CPAN
> >search engine.
> >To build on NT, you'll need to have a make utility, and some modules
> >require a C compiler.  You'll already have nmake if you have Visual C++
> >installed.
> >Don Silvia
> >At 10:24 AM Monday 5/7/2001, Janet Ciavarelli wrote:
> > >Well, I finally got mapscript compiled and installed into Active X Perl on
> > >a WinNT system. Whew! Now, when I go to run the shpinfo.pl, I get an error
> > >message cause it can't find XBase.pm I searched my whole system for
> > >XBase.pm and it's nowhere to be found. Where do I get XBase.pm from?
> > >Anyone know?
> > >Janet.
