[mapserver-users] Converting AVL files
Eduin Yesid Carrillo yecarrillo at hotmail.com
Tue May 15 17:57:29 EDT 2001
Actually I'm writing an mayor update for Maputils, a contributed ArcView
extension from Ross Searle to create map files and html stuff for web sites
using mapsever. This extensions reads all symbols from a view no matter if
they are assigned from ArcView or readed from avl files. All colors are
passed to map files as RGB values.
This extension has limitations due to Avenue language it self for reading
composite symbols, however, works really good for single symbols (lines,
points, and polygons) with colors, line width, outline color, view
background color, and other things.
This upgrade read views with sde layers (with avp files loaded too), and add
the correct parameters to the map file.
I can send you this ext for testing purposes, before posting for public
domain.
Ingeniero Civil
CIUDAD DIGITAL
Central de Información Regional Georefenciada
Bucaramanga - Colombia
yecarrillo at condorito.uis.edu.co
#ICQ 14323531
>From: Doug Nebert <ddnebert at fgdc.gov>
>To: Mapserver Users <mapserver-users at lists.gis.umn.edu>
>Subject: [mapserver-users] Converting AVL files
>Date: Tue, 15 May 2001 09:51:24 -0400
>Anyone have any experience translating an ArcView Legend file (ascii
>.avl) into a color palette assignment used in a .map file for mapserver?
>I assume this will get much easier as Arc 8 comes along and color
>assignments are done using ArcXML and RGB values (as in ArcExplorer 3.0
>using in ArcIMS and Arc 8).
>Doug.
>Douglas D. Nebert
>Geospatial Data Clearinghouse Coordinator
>FGDC/GSDI Secretariat	Phone: +1 703 648 4151	Fax: +1 703 648-5755
>Pager Messaging: 	http://clearinghouse3.fgdc.gov/dougmsg.html
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
