[mapserver-users] RH6.2 Install
Dennis Anthony
iblden at iblden.com
Thu May 17 07:17:48 EDT 2001
hello list,
i am attempting to compile mapserver 3.3.011 on my red hat 6.2 system.
Each time i compile i encounter a number of errors as seen in the
following config.log and output from the Configure execution. When I
execute the Make following the "Configure" I encounter numerous message
indicating
GNU Make version 3.78.1 is being used.,
" gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TTF -DUSE_TIFF
-DUSE_JPEG -DUSE_GD_1_3 -I/home/danthony/tools/mapserver/ms33/gdft
-I/usr/include/freetype ........"
I have attempted to compile with freetype installed via RPM as well as
from source, P
I have also installted the following components. The Configuration
below does not include the PROJ4 or shpelib packages. Though several
attempts were made with those ase well.
PROJ.4-4.4.1-1.i586.rpm
freetype-2.0.1.tar
shapelib-1.2.8-1.i586.rpm
jpegsrc.v6b.tar.gz ms_3.4.tar
Any help or suggestions would be appreciated.
dennis.
CONFIG.LOG
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
configure:569: checking for gcc
configure:682: checking whether the C compiler (gcc ) works
configure:698: gcc -o conftest conftest.c 1>&5
configure:724: checking whether the C compiler (gcc ) is a
cross-compiler
configure:729: checking whether we are using GNU C
configure:757: checking whether gcc accepts -g
configure:791: checking for ranlib
configure:821: checking for flex
configure:855: checking for yywrap in -lfl
configure:901: checking for bison
configure:933: checking if compiler supports -R
configure:968: checking if compiler supports -Wl,-rpath,
configure:1046: checking for exp in -lm
configure:1090: checking how to run the C preprocessor
configure:1170: checking for ANSI C header files
configure:1275: checking for strcasecmp
configure:1324: checking for strncasecmp
configure:1373: checking for strdup
configure:1430: checking which version of GD to use...
configure:1610: checking for gdImageGif in -lgd
configure:1629: gcc -o conftest -g -O2 conftest.c -lgd -lm 1>&5
configure:1650: checking for gdImageString16 in -lgd
configure:1669: gcc -o conftest -g -O2 conftest.c -lgd -lm 1>&5
configure:1690: checking for gdImagePng in -lgd
configure:1709: gcc -o conftest -g -O2 conftest.c -lgd -lpng -lz -lm
1>&5
/tmp/cc1svlmX.o: In function `main':
/home/danthony/tools/mapserver/ms33/configure:1705: undefined reference
to `gdImagePng'
collect2: ld returned 1 exit status
configure: failed program was:
#line 1698 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char gdImagePng();
int main() {
gdImagePng()
; return 0; }
configure:1791: checking whether we should include TIFF support...
configure:1942: checking for TIFFOpen in -ltiff
configure:1961: gcc -o conftest -g -O2 conftest.c -ltiff -lm 1>&5
configure:2047: checking whether we should include JPEG support...
configure:2106: checking for jpeg_read_header in -ljpeg
configure:2125: gcc -o conftest -g -O2 conftest.c -ljpeg -lm 1>&5
configure:2165: checking whether we should include EPPL7 support...
configure:2193: checking whether we should include Freetype (TTF)
support...
configure:2254: checking for TT_Init_FreeType in -lttf
configure:2273: gcc -o conftest -g -O2 conftest.c -lttf -lm 1>&5
configure:2295: checking for freetype.h
configure:2328: checking for TT_Init_FreeType in -lttf
configure:2371: checking for the location of freetype.h
configure:2452: checking whether we should include PROJ.4 support...
configure:2574: checking whether we should include ESRI SDE support...
configure:2801: checking for PHP3/MapScript module options...
*** Tail end of Config output to screen
checking for gdImageGif in -lgd... yes
checking for gdImageString16 in -lgd... yes
checking for gdImagePng in -lgd... no
using GD (-DUSE_GD_1_3) from system libs.
checking for TIFFOpen in -ltiff... yes
using libtiff from system libs.
checking for jpeg_read_header in -ljpeg... yes
using libjpeg from system libs.
including EPPL7 support.
checking whether we should include Freetype (TTF) support...
checking for TT_Init_FreeType in -lttf... yes
checking for freetype.h... (cached) no
checking for TT_Init_FreeType in -lttf... (cached) yes
checking for the location of freetype.h...
/usr/include/freetype/freetype.h
using libttf from system libs.
PROJ.4 support not requested.
ESRI SDE support not requested.
Compiling with -DIGNORE_MISSING_DATA.
PHP3/MapScript module not configured.
creating ./config.status
creating Makefile
creating gdft/Makefile
