[mapserver-users] PDF output, what about?
ANDREW WOOLEY AWOOLEY at mountainland.org
Wed May 23 09:18:36 EDT 2001
I am looking for this very solution.  The ToMo example is exactly what I would like to try on my site.  I am new to mapserver, but part of the reason I am doing any map serving is to allow some of my planners that are offsite print maps that they can customize.  Up to this point, I had resigned myself to the supposition that they would have to print a web map, but if a PDF or some other vector format is possible, I would really love to learn more.  I am still working on learning how mapserver works and if someone could send me some example code that shows how to create a PDF with mapserver on Linux instead of a bitmap of some sort, I would really appreciate it.  I am pretty familiar with PHP but am willing to learn anything.
Thanks very much,
Andrew
Andrew Wooley
GIS Operations Manager
Mountainland Association of Governments
Orem, UT
phone:  801.229.3844
fax:       801.229.3801
email:   awooley at mountainland.org
>>> Andréas M. Winter <winter at freytagberndt.at> 05/22 7:43 AM >>>
PDF is fine, SVG would be better when dealing with vector graphics on
the web.
have al look at http://www.karto.ethz.ch/cgi-bin/projection.pl and
http://www.carto.net/papers/svg . first is a projection tool with pdf
AND svg output, second a paper about the benefits of svg for
cartography!
regards
andré
____________________________________________
andréas m. winter - freytag & berndt
content management - new media & internet
austria a1230 wien brunner str 69
tel +43.1.869.90.90.38
fax +43.1.869.90.90.62
mailto:winter at freytagberndt.at
-----Ursprüngliche Nachricht-----
Von: Carlo A. Bertelli [mailto:bertelli at charta.acme.com]
Gesendet: Dienstag, 22. Mai 2001 12:45
An: mapserver-users at lists.gis.umn.edu
Betreff: [mapserver-users] PDF output, what about?
Hello fellows,
GIF and PNG output are very good for mapserver, as the browser does not
ask
for a plug-in to see maps, but when you need printing, screen-resolution
pictures are not so good.
I think mapserver should use a PDF library to provide PDF output for
printing purposes. Say, when you have the map you need (thematic
mapping,
scale, and so on), you would click on a 'PDF' button and presto! you get
a
print-ready image you could enhance or incorporate in documents.
Ciao
	Carlo
Carlo A. Bertelli
   Charta   servizi e sistemi per il territorio e la storia ambientale
srl
            Dipendenze del palazzo di Clemente Doria,
            vc. alla Chiesa della Maddalena 9/2 16124      Genova
(Italy)
            tel. +39 010 2475439  fax +39 010 2475439  cell: 0333
2298345
    e-mail: bertelli at charta.acme.com      http://www.charta.acme.com
