[mapserver-users] ArcSDE 8.1 for Linux
Andrea Goethals andreag at geoplan.ufl.edu
Wed May 23 12:55:57 EDT 2001
You are right. Sorry if I got anybody's hopes up. The documentation
that comes with it is very misleading. It says that they support
all hardware platforms supported by Oracle, Informix and DB2 and
tells you how to install it for Linux. But alas they did not provide
the install directory for linux for the server, just the client
libraries...
Andrea
> My understanding is that it's just the client libraries that are available.
> I have heard, unofficially, that full-blown Linux versions do exist but are
> not released.  The best thing to do is provide feedback to your ESRI
> representatives.  It will be a great solution once released (since Oracle
> and all other major RDBMS packages run on Linux).
> They will be on the disc labeled ArcSDE Client in a folder called
> red_hat_linux in your ArcGIS 8.1 box.
> The current Mapserv won't compile as-is with 8.1 client libs but Steve said
> he was going to work on it so....it's on the way.
> Lowell Ballard
> Unix/Database Administrator
> Virginia Economic Development Partnership
> 901 E. Byrd St., Richmond, Va. 23218
> http://gis.vedp.org
