[mapserver-users] Problem with PostGIS layer
Thomas Haechler
thaechl at geo.unizh.ch
Wed Aug 7 08:49:15 EDT 2002
Many thanks to Dave & Tyler for their help. I am posting this to the
list since I got emails from people with the same problem.
There was actually no problem with the user or permission because for
testing purpose I used the db-admin account. The solution is much more
simple:
I started the postmaster without allowing TCP/IP connetions. This option
is off by default, and since I run the webserver, mapserver and
postgresql on the same machine, I thought it is not necessary.
So for everyone with this problem: make sure to accept TCP/IP
connections. You have 2 possibilities to do this:
1.) use the -i option when starting the postmaster, or
2.) edit the postgresql.conf: tcpip_socket = true
Hope this helps someone else,
Thomy
THOMAS HAECHLER
Geographic Information Systems Division
Institute of Geography
University of Zurich
Switzerland
thomas.haechler at geo.unizh.ch
