[mapserver-users] GD compiling error.
Krung Saengpole
saengpole at excite.com
Fri Aug 30 15:06:56 EDT 2002
Michael, Thank you for your reply. I did as you suggested me but yet one error occured as following: /out:pngtogd.exe pngtogd.obj gd.lib libpng.lib zlib.lib libjpeg.lib freetype.lib pngtogd.obj : error LNK2001: unresolved external symbol _gdImageCreateFromPngpngtogd.exe : fatal error LNK1120: 1 unresolved externalsI also used gd-1.8.4 (tried both standard and patch version) and freetype-1.3.1. When I compiled freetype, I got freetype.lib so in gd's makefile.nt I write LIBS=gd.lib libpng.lib zlib.lib libjpeg.lib freetype.lib <------ Is it correct?Please don't be boring coz I'm not good at C language. Thank you again. Krung.--- On Thu 08/29, Michael Schulz < mschulz at webgis.de > wrote:From: Michael Schulz [mailto: mschulz at webgis.de]To: Cc: mapserver-users at lists.gis.umn.eduDate: Thu, 29 Aug 2002 10:47:08 +0200Subject: Re: [mapserver-users] GD compiling error.Hi,i) libttf refers to the freetype library that is needed to use truetypefonts in mapserver applications. I just compiled ms36x with gd184 andfreetype13. I couldn't manage to get it compiled with freetype212.ii) see the mapserver-list archive:http://mapserver.gis.umn.edu/wilma/mapserver-users/0105/msg00196.htmlI had the same problem. Also note that there is are patched version ofthe gdlib184 with gif-support. you can find the link in the mapservercompilation docs.If you have further problems, i will happily share my experiences of thelast days...Cheers, Michael
Changed your e-mail? Keep your contacts! Use this free e-mail change of address service from Return Path. Register now!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020830/914c5d7b/attachment.html
