[mapserver-users] TRUETYPE not work
Zhang, William
wzhang at c-cor.net
Fri Aug 30 16:12:54 EDT 2002
Steve,
Yes, I have the MapFile Reference document. I did not specify font in my map
file just for simplifying the test. I thought that some default font would
be used by mapserver if no font is specified by user. Is this true? Anyway
now I add font related lines in the map file below. It still does not work.
NAME alm
EXTENT -122.0837 37.6683 -122.1104 37.6885
SIZE 800 600
SHAPEPATH "C:\Inetpub\wwwroot\itasca\test\tutorial35"
FONTSET "C:\Inetpub\wwwroot\itasca\test\fonts\fonts.list"
LAYER
TYPE LINE
STATUS DEFAULT
DATA alm
LABELITEM "FENAME"
CLASS
COLOR 255 0 0
LABEL
TYPE TRUETYPE
ANTIALIAS
FONT arial
COLOR 0 0 0
ANGLE AUTO
POSITION UC
END
END
END
END # end of map file
I have one line in the fonts.list file
arial arial.ttf
I also copy the arial.ttf file to the same directory as fonts.list located.
Do I miss something else?
Thank you for the help.
William
-----Original Message-----
From: woodbri at swoodbridge.com [mailto:woodbri at swoodbridge.com]
Sent: Thursday, August 29, 2002 7:32 PM
To: Zhang, William; mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] TRUETYPE not work
William,
Do you have a Map file Reference document?
You need to look at the LABEL section, you will see that it mentions
a FONT tag which references an item in a FONTSET. The document will
also tell you how to set up the FONTSET file which will need to point
to the the fonts on your system.
The documentation page can be found off the Mapserver home page.
-Steve
On 29 Aug 2002 at 22:04, Zhang, William wrote:
> Hi,
> I got error in the map file below. If I comment out TRUETYPE releated
lines,
> the map file works. I downloaded the mapserv.exe from Windows Binary
> Download page, so it should be TRUETYPE enabled. Could somebody give me
help
> on this one?
> NAME alm
> SIZE 800 600
> LAYER
> TYPE LINE
> STATUS DEFAULT
> DATA alm
> LABELITEM "FENAME"
> CLASS
> COLOR 255 0 0
> LABEL
> TYPE TRUETYPE
> ANTIALIAS
> COLOR 0 0 0
> ANGLE AUTO
> POSITION UC
> END
> END
> END
> Thanks,
> William Zhang
> Software Engineer
> C-Cor.net
> Phone: (925) 251-3019
> Fax: (925) 467-0600
> E-Mail: wzhang at c-cor.net
