[Mapserver-users] PHP/MapScript
daniel.berstein at dmapas.com daniel.berstein at dmapas.com
Wed Dec 4 12:03:08 EST 2002
I believe you are using incompatible version of php_mapscript and php
(php_mapscript_X.dll and php version Y).
What version of PHP are you using? Create a test.phtml file with the
following line:
<?php phpinfo();?>
The output of the above script should tell your PHP version (and probably
the same error you are reporting). Then take a look at your extensions
directory (on Windows usually C:\Php\extensions) and search for
php_mapscript_NN.dll. NN should be the version of php_mapscript you are
using.
Regards,
Daniel Berstein Z.
Jefe de Proyectos, dmapas.com
Eduardo Hyatt 583, Providencia, Santiago CHILE
*(56) (2) 222 22 60
-----Mensaje original-----
De:	LUIS FRANCISCO ARAYA ARANA [SMTP:araya_lf at hotmail.com]
Enviado el:	Miercoles, 04 de Diciembre de 2002 13:39
Para:	mapserver-users at lists.gis.umn.edu
Asunto:	[Mapserver-users] PHP/MapScript
I'm developing a app that need to render a point from a given
coordinate... I try to use php/mapscript, but php give me the next
warning:
PHP Warning: MapScript: Unable to initialize module
Module compiled with debug=0, thread-safety=0 module API=20020429
PHP compile with debug=0, thread-safety=0 module API=20010901
These option need to match
in Unknown on line 0
Someone know why???
Is there other way to draw a point without using the MapScript?
Because I dont want to use php as a CGI.... I configure the Web Server
to run the scripts when the they end with .phtml extension and when they
end with the .php it uses the DSO.
Any help?
Thank you...
  _____
Obtenga el maximo provecho del Web. Descarga GRATUITA de MSN Explorer:
http://explorer.msn.es/intl.asp#es <http://explorer.msn.es/intl.asp#es>
 <<Archivo: ATT00001.htm>>
