[Mapserver-users] SDE queries are different
Murray, Ross rmurray at NRCan.gc.ca
Wed Dec 4 14:05:11 EST 2002
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_000_01C29BC8.11D15090
Content-Type: text/plain;
	charset="iso-8859-1"
I have a javascript function that builds a string (from an Oracle database)
that is used as a layer filter. For example, the script may produce
	' [CODE] ' = ' somevalue '
which is passed to Mapserver as the value for map_somelayer_filter.
This works fine, only so long as the underlying source is a shapefile. If
the layer is an SDE layer I have to use
	CODE = ' somevalue '
So I have to now test to see if the layer being queried is a SDE layer!
Has anyone else had this problem, i.e. is this a bug that should be
reported?
 <<Murray, Ross.vcf>>
Content-Type: application/octet-stream;
	name="Murray, Ross.vcf"
Content-Disposition: attachment;
	filename="Murray, Ross.vcf"
BEGIN:VCARD
VERSION:2.1
N:Murray;Ross
FN:Murray, Ross
ORG:NRCAN.RNCAN;ESS.SST
TITLE:Information Management and GIS Technician
TEL;WORK;VOICE:947-1411 (613)
TEL;CELL;VOICE:
ADR;WORK:;2 - 255;601 Booth Street;Ottawa;ON;K1A 0E8;CA
LABEL;WORK;ENCODING=QUOTED-PRINTABLE:2 - 255=0D=0A601 Booth Street=0D=0AOttawa, ON K1A 0E8=0D=0ACA
EMAIL;PREF;INTERNET:rmurray at NRCan.gc.ca
REV:20020717T171556Z
END:VCARD
------_=_NextPart_000_01C29BC8.11D15090--
