AW: [Mapserver-users] Compiling the boxzooming mapplet
Nicole Bomeke bon at ivv-aachen.de
Tue Dec 3 12:23:05 EST 2002
Thanks for the reply.
I found a file mayscript.jar that contains the classes required for the Live
Connect mechanism
under http://www.applepiesolutions.com/mayscript/.
I saved it as c:\j2sdk1.4.0_01\lib\mayscript.jar and added it to the
CLASSPATH.
Now I can compile the boxzooming mapplet with my jdk :-)
Your experience with Sun Java 1.3 sdk is very interesting.
I indeed have problems to run my applets under IE.
I will try if it works better with version 1.3.
Nicole
-----Ursprungliche Nachricht-----
Von: Richard Greenwood [mailto:Rich at GreenwoodMap.com]
Gesendet: Dienstag, 3. Dezember 2002 16:24
An: Nicole Bomeke
Cc: mapserver-users at lists.gis.umn.edu
Betreff: Re: [Mapserver-users] Compiling the boxzooming mapplet
At 01:27 PM 12/3/2002 +0100, you wrote:
>What ist necessary to compile the boxzooming mapplet?
>When I try to compile it with suns standard edition 1.4.0_01 of the jdk I
>get the error
>"package netscape,javascript does not exist".
You need the Live Connect classes, which I think I found on the netscape
site. They are in "winNPSDK.zip" or "winsdk40.zip".  I found the Sun Java
1.3 sdk worked better (it produced code that ran under IE)
>When I try to compile it with Microsoft Visual J++ I get the error message
>"createCustomCursor is not a method of class toolkit".
I never got the MS compiler to work.
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
(307) 733-0203
http://www.GreenwoodMap.com
