[Mapserver-users] sub-select
Jan Hartmann jhart at frw.uva.nl
Fri Dec 20 07:55:05 EST 2002
Nida,
You have to put SRID in capitals!. This is a small but very annoying bug
that has been reported before
(http://postgis.refractions.net/pipermail/postgis-users/2002-November/001757.html)
but has not been resolved yet.
Jan Hartmann
nida Khan wrote:
> Hi Everyone,
> I want to do a subselect from my .map file. I went through some
> list-archive from that I tried these statements.
> DATA "the_geom from westminster"  works fine
> DATA "the_geom from westminster using unique oid using srid=-1"    works
> fine
> DATA "the_geom from (select oid,the_geom from westminster) as foo using
> unique oid using srid=-1"  no result
> I've got two tables, one with geom, other with features... I want to
> display the certain feature as label on the map.
> What I'm missing in the above sql? Am I doing anything wrong? Is there
> anything on database level that I have to change?
> Will Appreciate any inputs
> Regards
> Nida.
Jan Hartmann
Department of Geography
University of Amsterdam
jhart at frw.uva.nl
