[Mapserver-users] sub-select
nida Khan
nida at webstar.co.uk
Fri Dec 20 09:10:41 EST 2002
hmmmmm... strange
its seems really odd, it works other way round for me.
when I do
the_geom from westminster using unique oid using SRID=-1
it does NOT work
but this one does
the_geom from westminster using unique oid using srid=-1
And when I add
the_geom from (select oid,the_geom from westminster) as foo using unique oid
using srid=-1
it does not display that layer!!!
Can you also explain me or point me to a right document which explain the
logic of using "srid"??
I'm kinda stuck at this point :(.
Thank you very much for your response!
Regards
Nida.
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Friday, December 20, 2002 12:55 PM
Subject: Re: [Mapserver-users] sub-select
> Nida,
> You have to put SRID in capitals!. This is a small but very annoying bug
> that has been reported before
(http://postgis.refractions.net/pipermail/postgis-users/2002-November/001757
.html)
> but has not been resolved yet.
> Jan Hartmann
> nida Khan wrote:
> > Hi Everyone,
> > I want to do a subselect from my .map file. I went through some
> > list-archive from that I tried these statements.
> > DATA "the_geom from westminster" works fine
> > DATA "the_geom from westminster using unique oid using srid=-1" works
> > fine
> > DATA "the_geom from (select oid,the_geom from westminster) as foo using
> > unique oid using srid=-1" no result
> > I've got two tables, one with geom, other with features... I want to
> > display the certain feature as label on the map.
> > What I'm missing in the above sql? Am I doing anything wrong? Is there
> > anything on database level that I have to change?
> > Will Appreciate any inputs
> > Regards
> > Nida.
> Jan Hartmann
> Department of Geography
> University of Amsterdam
> jhart at frw.uva.nl
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
