[mapserver-users] Initial pre-alpha release of the CLX component for Delphi
Pedro A. Carrasco pcarrasco at iver.es
Tue Jan 8 07:24:00 EST 2002
    Hi all,
    I'm developing a CLX component to access MapServer from Delphi
Applications, my intention is to make a component similar to MapObjects
(only similar, not the same, more like MapObjects LT), but working with the
MapServer enviroment. I develop it in Delphi beacouse it can compile in
Kylix (Linux). The pre-alpha release can be downloaded from
http://www.polaris2000.net/_temp/mapserverdelphi.exe it only make zoom in,
zoom out, and pan (and full extent), it have two directories, one with the
clx control and the other with the sample aplication I use, tha application
is code linked with my .map file and layers, this code can be changed for
the use with others .map and layers.
    I hope it will be usefull.
    Regards.
Pedro A. Carrasco Ponce
IVER Sistemas de Información Geográfica
Dpto. Técnico
C/Salamanca, 50
46005 Valencia
Tlf: 96 316 34 00 Fax: 96 316 2716
mail : pcarrasco at iver.es
web : http://www.iver.es
