[mapserver-users] (no subject)
Jamie Smedsmo
jsmedsmo at gis.umn.edu
Tue Jan 8 10:39:31 EST 2002
-------- Original Message --------
Date: Tue, 08 Jan 2002 07:05:08 -0800
To: "'mdp at lists.gis.umn.edu'" <mdp at lists>
Hello mapserver users:
we installed mapserver 3.5 (with WMS support) yo can see at
http://gisweb/Mapserver/ms_clima35/clima_init2.html
but when using
http://gisweb.ciat.cgiar.org/cgi-bin/mapserv.exe?map=d:/Inetpub/wwwroot/Maps
erver/ms_clima35/cgiar.map&WMTVER=1.0.7&REQUEST=GetMap
to generate a map with the default map size and all the layers with STATUS
ON or DEFAULT , i get a save dialog (to save mapserv)
can anybody give some help?
William
below the .map file
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 600
EXTENT -92.221795 7.201854 -77.238755 17.817886
UNITS DD
SHAPEPATH "/Mapserver/ms_clima35/data"
IMAGECOLOR 255 255 255
# Projection definition, consult the PROJ.4 documentation for parameter
discussion
#PROJECTION
# "init=epsg:4326"
#END
# Start of web interface definition
WEB
HEADER clima2_header.html
TEMPLATE clima2.html
FOOTER clima2_footer.html
MINSCALE 1000000
MAXSCALE 30000000
IMAGEPATH "d:\Inetpub\wwwroot\tmp\"
IMAGEURL "\tmp\"
# LOG "demo.log"
METADATA
"wms_title" "CIAT Web Map Service"
"wms_onlinesource"
"http://gisweb.ciat.cgiar.org/cgi-bin/mapserv.exe?map=d:/Inetpub/wwwroot/Map
server/ms_clima35/clima4.map&"
"wms_srs" "EPSG:4326"
END
END
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of reference map
REFERENCE
IMAGE graphics/camer.jpg
EXTENT -93.964081 7.097332 -77.17411 19.706318
SIZE 219 174
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 50 2
COLOR 255 255 255
UNITS METERS
INTERVALS 1
TRANSPARENT TRUE
STATUS TRUE
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS
1 1
END
FILLED
END
# Start of layer definitions
LAYER
NAME centroamer
STATUS DEFAULT
TYPE POLYGON
DATA paises-centro
CLASSITEM 'nombre'
CLASS
EXPRESSION 'Itasca'
OUTLINECOLOR 128 128 128
COLOR 225 225 185
END
CLASS # every other county in the state
EXPRESSION /./
COLOR 255 255 255
END
END
LAYER
NAME clima
METADATA
"wms_title" "Drought risk"
END
TYPE POLYGON
DATA climrisk
STATUS OFF
CLASSITEM Gridcode
CLASS
NAME "< 3 cons. dry months"
EXPRESSION '0'
COLOR 254 236 205
OUTLINECOLOR 254 236 205
END
CLASS
NAME "4-6 cons. dry months"
EXPRESSION '1'
COLOR 253 220 106
OUTLINECOLOR 253 220 106
END
CLASS
NAME "> 6 cons. dry months"
EXPRESSION '2'
COLOR 253 182 74
OUTLINECOLOR 253 182 74
END
CLASS
NAME "< 3 cons. dry month + flood"
EXPRESSION '3'
COLOR 166 204 204
OUTLINECOLOR 166 204 204
END
CLASS
NAME "4-6 dry months + flood"
EXPRESSION '4'
COLOR 5 208 214
OUTLINECOLOR 5 208 214
END
CLASS
NAME "> 6 dry months + flood"
EXPRESSION '5'
COLOR 78 160 156
OUTLINECOLOR 78 160 156
END
END
LAYER
NAME poblacion
METADATA
"wms_title" "Population"
END
TYPE POLYGON
DATA popgeo
STATUS ON
CLASSITEM Density
CLASS
EXPRESSION ([DENSITY] > 0 and [DENSITY] <= 10)
Name '0 - 10 '
COLOR 255 237 221
OUTLINECOLOR 255 237 221
END
CLASSITEM Density
CLASS
EXPRESSION ([DENSITY] > 10 and [DENSITY] <=25)
Name '10 - 25 '
COLOR 255 216 181
OUTLINECOLOR 255 216 181
END
CLASSITEM Density
CLASS
EXPRESSION ([DENSITY] > 25 and [DENSITY] <= 50)
Name '25 - 50 '
COLOR 255 194 140
OUTLINECOLOR 255 194 140
END
CLASSITEM Density
CLASS
EXPRESSION ([DENSITY] > 50 and [DENSITY] <= 100)
Name '50 - 100 '
COLOR 255 174 102
OUTLINECOLOR 255 174 102
END
CLASSITEM Density
CLASS
EXPRESSION ([DENSITY] > 100 and [DENSITY] <=200)
Name '100 - 200 '
COLOR 255 159 72
OUTLINECOLOR 255 159 72
END
CLASSITEM Density
CLASS
EXPRESSION ([DENSITY] > 200 and [DENSITY] <= 500)
Name '200 - 500 '
COLOR 255 159 72
END
CLASSITEM Density
CLASS
EXPRESSION ([DENSITY] > 500 and [DENSITY] <= 1000)
Name '500 - 1000 '
COLOR 240 114 0
OUTLINECOLOR 240 114 0
END
CLASSITEM Density
CLASS
EXPRESSION ([DENSITY] > 1000 and [DENSITY] <= 2500)
Name '1000 - 2500 '
COLOR 213 101 0
OUTLINECOLOR 213 101 0
END
CLASSITEM Density
CLASS
EXPRESSION ([DENSITY] > 5000 and [DENSITY] <=55000)
Name '< 5000 '
COLOR 145 69 0
OUTLINECOLOR 145 69 0
END
HEADER poblacion2_header.html
TEMPLATE poblacion2.html
FOOTER poblacion2_footer.html
TOLERANCE 3
END
LAYER
NAME riesgo
METADATA
"wms_title" "Hazard risk"
END
TYPE POLYGON
DATA forrisk
STATUS OFF
CLASSITEM Gridcode
CLASS
NAME "Riesgo Alto"
EXPRESSION '1'
COLOR 201 153 7
OUTLINECOLOR 201 153 7
END
CLASSITEM Gridcode
CLASS
NAME "Riesgo Intermedio"
EXPRESSION '2'
COLOR 208 174 55
OUTLINECOLOR 208 174 55
END
CLASSITEM Gridcode
CLASS
NAME "Bajo"
EXPRESSION '3'
COLOR 40 173 181
OUTLINECOLOR 40 173 181
END
CLASSITEM Gridcode
CLASS
NAME "Alto-Coniferas"
EXPRESSION '4'
COLOR 253 198 9
OUTLINECOLOR 253 198 9
END
CLASSITEM Gridcode
CLASS
NAME "Intermedio-Coniferas"
EXPRESSION '5'
COLOR 254 224 122
OUTLINECOLOR 254 224 122
END
CLASSITEM Gridcode
CLASS
NAME "Bajo-Coniferas"
EXPRESSION '6'
COLOR 94 206 219
OUTLINECOLOR 94 206 219
END
END
LAYER
NAME riescost
METADATA
"wms_title" "Riesgo Costero"
END
TYPE POLYGON
DATA costrisk2
STATUS OFF
CLASSITEM Costrisk
CLASS
NAME "Riesgo Alto"
EXPRESSION '1'
COLOR 247 191 2
OUTLINECOLOR 247 191 2
END
CLASSITEM Costrisk
CLASS
EXPRESSION '2'
COLOR 10 219 224
OUTLINECOLOR 10 219 224
END
CLASSITEM Costrisk
CLASS
NAME "Riesgo Bajo"
EXPRESSION '3'
COLOR 174 216 217
OUTLINECOLOR 174 216 217
END
CLASSITEM Costrisk
CLASS
NAME "Influencia de Puertos"
EXPRESSION '4'
COLOR 127 127 127
OUTLINECOLOR 127 127 127
END
CLASSITEM Costrisk
CLASS
NAME "Influencia Infraestrucura"
EXPRESSION '5'
COLOR 223 223 223
OUTLINECOLOR 223 223 223
END
END
LAYER
NAME usotierra
METADATA
"wms_title" "Land Use"
END
TYPE POLYGON
DATA conflic
STATUS OFF
CLASSITEM Gridcode
CLASS
NAME "Uso Apropiado"
EXPRESSION '1'
COLOR 181 208 138
OUTLINECOLOR 181 208 138
END
CLASSITEM Gridcode
CLASS
NAME "Agricultura Inapropiada"
EXPRESSION '2'
COLOR 242 170 0
OUTLINECOLOR 242 170 0
END
CLASSITEM Gridcode
CLASS
NAME "Uso Inapropiado"
EXPRESSION '3'
COLOR 125 0 0
OUTLINECOLOR 125 0 0
END
CLASSITEM Gridcode
CLASS
NAME "Potencial para Agricultura"
EXPRESSION '4'
COLOR 3 168 186
OUTLINECOLOR 3 168 186
END
END
LAYER
NAME accesib
METADATA
"wms_title" "Accesibility"
END
TYPE POLYGON
DATA acc_cam
STATUS OFF
CLASSITEM Gridcode
CLASS
NAME "0-10 mins"
EXPRESSION '1'
COLOR 255 255 104
OUTLINECOLOR 255 255 104
END
CLASSITEM Gridcode
CLASS
NAME "10-20 mins"
EXPRESSION '2'
COLOR 255 255 202
OUTLINECOLOR 255 255 202
END
CLASSITEM Gridcode
CLASS
NAME "20-40 mins"
EXPRESSION '3'
COLOR 255 191 191
OUTLINECOLOR 255 191 191
END
CLASSITEM Gridcode
CLASS
NAME "40-60 mins"
EXPRESSION '4'
COLOR 255 164 164
OUTLINECOLOR 255 164 164
END
CLASSITEM Gridcode
CLASS
NAME "60-120 mins"
EXPRESSION '5'
COLOR 208 0 0
OUTLINECOLOR 208 0 0
END
CLASSITEM Gridcode
CLASS
NAME "120-240 mins"
EXPRESSION '6'
COLOR 142 0 0
OUTLINECOLOR 142 0 0
END
CLASSITEM Gridcode
CLASS
NAME "240-480 mins"
EXPRESSION '7'
COLOR 104 0 0
OUTLINECOLOR 104 0 0
END
CLASSITEM Gridcode
CLASS
NAME "480-3840 mins"
EXPRESSION '8'
COLOR 0 0 0
OUTLINECOLOR 0 0 0
END
END
LAYER
NAME centroamer
METADATA
"wms_title" "Boundaries"
END
TYPE POLYLINE
DATA paises-centro
STATUS OFF
CLASS
SYMBOL 'circle'
SIZE 1
NAME 'Division Politica'
COLOR 181 181 145
END
END
END # Map File
William Diaz S. email: w.diaz at cgiar.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020108/99a41daa/attachment.html
