[mapserver-users] gmap75 Help
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jan 8 19:58:58 EST 2002
Sorry to be tedious about this, but I would really like to get this
working. Can anyone at dmsolutions give me a hand with this? Please.
I have narrowed things down a little more and it looks like I can only
access layer 0 inspite of the fact that the mapObj reports it has 11
layers. I have been dumping out properties of the objects I can access
with this url
http://swoodbridge.com/web2/gmap/htdocs/t3.php3?lay=0
if you change the zero to one it will segv.
This seems like pretty basic mapscript internals to me. Is there a patch
or something I am missing.
-Steve
Stephen Woodbridge wrote:
> A further update!
> I changed the first if block in gmap75.php3 to
> if (isset($HTTP_POST_VARS))
> $HTTP_FORM_VARS = $HTTP_POST_VARS;
> else if (isset($HTTP_GET_VARS))
> $HTTP_FORM_VARS = $HTTP_GET_VARS;
> else
> $HTTP_FORM_VARS = array("");
> to get by the problem of loading that, but ran into the following
> problem that I have narrowed down to the line gmap75.php3:506
> $poLayer = $gpoMap->getlayerbyname($szLayerName);
> which segvs when it it first called from gmap75.phtml:175 via
> GMapGetStatus("road")
> I don't think I can take this much further.
> Does anyone have a clue as to what I should check or do next?
> -Steve
> > I have a little bit more on this. I have narrowed it down to the
> > include("gmap75.php3"); line, which by the way should be written as
> > include("./gmap75.php3") to force php to look in the local directory and
> > not in the include path if one is set in the php3.ini file as is my
> > case. This would make it more portable to other people's systems.
> > I wrote 2 trivial scripts at
> > http://swoodbridge.com/web2/gmap/htdocs/t.php3
> > http://swoodbridge.com/web2/gmap/htdocs/t2.php3
> > where t.php3 is:
> > <html>
> > <?php
> > if (!extension_loaded("MapScript"))
> > dl("php_mapscript.so"); // Same name for PHP3 and PHP4
> > include("./gmap75.php3");
> > phpinfo();
> > </html>
> > and t2.php3 is the same except the include is commented out. You will
> > notice that the phpinfo() output is truncated on t.php3 and not on
> > t2.php3. There is also a segv logged in the error_log for t.php3.
> > Any ideas?
> > -Steve
> > > Hi all,
> > > I just downloaded gmap75 to try with the released mapserver 3.5 and ran
> > > into the following problems:
> > > 1) the symbols.sym file needs to be edited to change all line:
> > > "Filled" to "Filled TRUE"
> > > 2) when I tried to load the initial page I go back "The document
> > > contained no data." dialog box and the apache error log:
> > > [Tue Jan 8 08:42:29 2002] [notice] child pid 18409 exit signal
> > > Segmentation fault (11)
> > > My config setup is at:
> > > http://swoodbridge.com/web2/ms_test/phpinfo_mapscript.php3
> > > and the gmap demo is at:
> > > http://swoodbridge.com/web2/gmap/htdocs/index.php3
> > > I edited the map file for this location. Are there any other hard coded
> > > paths that might cause this?
> > > Any suggestions on how to debug this?
> > > Any help would be appreaciated.
> > > -Steve Woodbridge
