[mapserver-users] problem with mapserver 3.5 demo. (FWD)
Tyler Mitchell
TMitchell at lignum.com
Mon Jan 21 12:10:30 EST 2002
Oh how familiar :) I was just combating the same problem last night. If
you are using the standard/latest version GD it does not support GIF files.
If you convert all the GIF files referred to in your demo.map file -> to
PNG files, it will work fine.
I've attached versions the file that I converted. Put the images into your
symbols folder and the reference.png into the graphics folder. Then edit
demo.map to reflect the change from GIF -> PNG, by renaming each occurence
in the file.
Steven, can you put this into the demo package - it is a very common
problem. (These may not be the best converted versions though :)Am I right
in assuming that GD does not and will not support GIF and we should all
move to PNG?
Tyler
(See attached file: ushwy.png)(See attached file: interstate.png)(See
attached file: reference.png)(See attached file: sthwy.png)(See attached
file: ctyhwy.png)
teb <teb at mallit.fr.umn.edu>
Sent by: To: mapserver-users at lists.gis.umn.edu
owner-mapserver-users at lists.g cc: fgclaram at alu-ab.uclm.es
is.umn.edu Fax to:
Subject: [mapserver-users] problem with mapserver 3.5 demo. (FWD)
01/21/2002 07:01 AM
Please respond to teb
------------- Begin Forwarded Message -------------
X-Sender: fgclaram at correo.alu-ab.uclm.es
Date: Mon, 21 Jan 2002 13:07:29 +0100
To: mapserver-info at lists.gis.umn.edu
Subject: problem with mapserver 3.5 demo.
Mime-Version: 1.0
X-AntiVirus: scanned for viruses by AMaViS 0.2.1 (http://amavis.org/)
Hello.
I have installed the mapserver 3.5 an GD Library. (under Linux).
I am installing the mapserver 3.5. demo, and i done all the steps in
documentation
http://mapserver.gis.umn.edu/demo_readme.html,
but when i call demo_init.html page, I get the next message:
msLoadMap(): General error message. Undefined symbol
"symbols/ctyhwy.gif"
in class 0 of layer ctyrdln3_anno.
the symbols/ctyhwy.gif file exist.
I do not know the wrong. What is the matter?
Could you help me?.
Thank you.
Regards!
Fran.
------------- End Forwarded Message -------------
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020121/e9beed68/ushwy.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020121/e9beed68/interstate.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020121/e9beed68/reference.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020121/e9beed68/sthwy.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020121/e9beed68/ctyhwy.png
