[mapserver-users] problem with mapserver 3.5 demo. (FWD)
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jan 21 12:27:05 EST 2002
Tyler et al,
The issue of GD supporting GIFs has come up many times before. You can
get a patch that will add gif support to GD if you want it check the
list archives. There is obviously a licensing issue using GIFs that
everyone has to decide how you want to deal with on you own basis.
-Steve
Tyler Mitchell wrote:
> Oh how familiar :) I was just combating the same problem last night. If
> you are using the standard/latest version GD it does not support GIF files.
> If you convert all the GIF files referred to in your demo.map file -> to
> PNG files, it will work fine.
> I've attached versions the file that I converted. Put the images into your
> symbols folder and the reference.png into the graphics folder. Then edit
> demo.map to reflect the change from GIF -> PNG, by renaming each occurence
> in the file.
> Steven, can you put this into the demo package - it is a very common
> problem. (These may not be the best converted versions though :)Am I right
> in assuming that GD does not and will not support GIF and we should all
> move to PNG?
> Tyler
> (See attached file: ushwy.png)(See attached file: interstate.png)(See
> attached file: reference.png)(See attached file: sthwy.png)(See attached
> file: ctyhwy.png)
> teb <teb at mallit.fr.umn.edu>
> Sent by: To: mapserver-users at lists.gis.umn.edu
> owner-mapserver-users at lists.g cc: fgclaram at alu-ab.uclm.es
> is.umn.edu Fax to:
> Subject: [mapserver-users] problem with mapserver 3.5 demo. (FWD)
> 01/21/2002 07:01 AM
> Please respond to teb
> ------------- Begin Forwarded Message -------------
> X-Sender: fgclaram at correo.alu-ab.uclm.es
> Date: Mon, 21 Jan 2002 13:07:29 +0100
> To: mapserver-info at lists.gis.umn.edu
> From: Francisco <fgclaram at alu-ab.uclm.es>
> Subject: problem with mapserver 3.5 demo.
> Mime-Version: 1.0
> X-AntiVirus: scanned for viruses by AMaViS 0.2.1 (http://amavis.org/)
> Hello.
> I have installed the mapserver 3.5 an GD Library. (under Linux).
> I am installing the mapserver 3.5. demo, and i done all the steps in
> documentation
> http://mapserver.gis.umn.edu/demo_readme.html,
> but when i call demo_init.html page, I get the next message:
> msLoadMap(): General error message. Undefined symbol
> "symbols/ctyhwy.gif"
> in class 0 of layer ctyrdln3_anno.
> the symbols/ctyhwy.gif file exist.
> I do not know the wrong. What is the matter?
> Could you help me?.
> Thank you.
> Regards!
> Fran.
> ------------- End Forwarded Message -------------
> ushwy.png Type: PNG Image (image/png)
> Encoding: base64
> interstate.png Type: PNG Image (image/png)
> Encoding: base64
> reference.png Type: PNG Image (image/png)
> Encoding: base64
> sthwy.png Type: PNG Image (image/png)
> Encoding: base64
> ctyhwy.png Type: PNG Image (image/png)
> Encoding: base64
