[mapserver-users] tiff problem,
Pushkar Pradhan pushkar at ERC.MsState.Edu
Mon Jan 28 12:53:37 EST 2002
I am trying to display tiffs using MS 3.5. I get the foll. as part of
the mesg. when I run my configure script:
checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
        using libjpeg from system libs.
checking whether we should include TIFF support...
checking for TIFFOpen in -ltiff... yes
        using libtiff from system libs.
And if I've understood correctly TIFF support is included when I do a
normal 'make'.
The foll. is my layer defn. for tiff:
LAYER
   NAME mosaic_1999_false
   TYPE RASTER
   STATUS DEFAULT
   DATA data/mosaic_1999_false.tif
END
The images are 8-bit so should render correctly, but all I get is a blank
image. I used examples from the mailing list archive to define the layer.
If anybody can point out the problem. Thanks,
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
