[mapserver-users] [Fwd: example1]
Tyler Mitchell TMitchell at lignum.com
Tue Jan 29 12:49:14 EST 2002
Does the map file have to have a .map extension maybe?  I don't know but
maybe .map2 is not legal.
                    Jamie Smedsmo
                    <jsmedsmo at gis.umn.edu>              To:     mapserver-users at lists.gis.umn.edu
                    Sent by:                            cc:     orkun <temiz at deprem.gov.tr>
                    owner-mapserver-users at lists.g       Fax to:
                    is.umn.edu                          Subject:     [mapserver-users] [Fwd: example1]
                    01/29/2002 08:10 AM
-------- Original Message --------
 Subject: example1
    Date: Tue, 29 Jan 2002
          16:13:09 +0200
      To: projects at lists
Hi
I am newly acquaint with mapserver.
So I am trying to learn the basic things.
The problem I have run into is:
firstly I prepared a html file to fire up as:
<html>
<head><title>Heyelan</title></head>
<body bgcolor="#FFFFFF">
<center><h2>heyelan</h2></center>
<p><hr><p>
<form method=GET action="/cgi-bin/mapserv">
<input type="hidden" name="map" value="/var/www/html/demo.map2">
<input type="hidden" name="layer" value="heyha6">
<input type="hidden" name="program" value="/cgi-bin/mapserv">
<center><input type="submit" value="Initialize"></center>
</form>
</body></html>
Then maplist (as demo.map2)
NAME map
EXTENT 4660000 4520000 480000 640000
SIZE 100 100
SHAPEPATH "/var/www/html"
LAYER
 NAME "hey_ha6"
 DATA hey_ha6
 STATUS DEFAULT
 TYPE POLYGON
 CLASS
   COLOR 250 175 25
 END # end of class object
END # end of layer object
END # end of map file
But every time I get this message : msLoadMap(): Unable to access file.
Illegal mapfile name.
could you tell me what I didn't  fulfill ?
I look at the example1. if I am not wrong, that only contains two files and
doesn't any template file.
I just want see a single map shape file.
How can I do that with a GRASS map?
Thanks in advance
Ahmet Temiz
______________________________________
Scanned and protected by Inflex
http://pldaniels.com/inflex
