[mapserver-users] Re: Happy New Year! and a problem. :)
Vinko Vrsalovic B. v at w.cl
Tue Jul 2 17:24:38 EDT 2002
> "STATUS ON" will turn a layer on when used from shp2img or the other =
> command line utilties but has no effect with the CGI program. You must =
> explicitly request the layer. That's the first place I'd check, then I'd =
> make sure the image extents match your other data.
The problem is i'm using PHP/Mapscript, not the CGI version,
and the extents are right (they have been checked more than
10 times, i'd say)
V. <v at w.cl>
