Fw: [mapserver-users] Urgent - "imgshape" and MS 3.5/3.6
Alfred Kleva alfred.kleva at siol.net
Mon Jul 1 15:44:25 EDT 2002
I have tested on ShapeFile and PostGIS layer.
On ShapeFile works OK
On PostGIS 0.60 layer return error :
Internal Server Error
The server encountered an internal error or misconfiguration and was unable
to complete your request.
Please contact the server administrator, root at localhost and inform them of
the time the error occurred, and anything you might have done that may have
caused the error.
More information about this error may be available in the server error log.
Alfred Kleva
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>; <robert-fritz at web.de>
Sent: Monday, July 01, 2002 5:46 PM
Subject: Re: [mapserver-users] Urgent - "imgshape" and MS 3.5/3.6
> The bug that was filed via Bugzilla was fixed in version 3.6.1 and was
> correct in the 3.7 development code. I've not tested the full
> functionality though in some time, so if someone could confirm that all
> is well then that would be helpful.
> Steve
> >>> "Robert Fritz" <robert-fritz at web.de> 07/01/02 10:35AM >>>
> Hello,
> I try to use "imgshape" to query my maps, but I get either wrong data
> or
> nothing.
> Does "imgshape" not work ( see:
"http://mapserver.gis.umn.edu/cgi-bin/wilma_hiliter/mapserver-users/0205/msg
> 00033.html?line=23#hilite") or do I do a mistake?
> 1. Is there any Mapserver Version, where "imgshape" works?
> 2. Does the Mapscript "queryByShape" function works? (is it similar to
> "imgshape"?)
> Thank you,
> Robert
