[mapserver-users] PHP queryByRect problem.
Pedro A. Carrasco pcarrasco at iver.es
Tue Jul 2 03:02:37 EDT 2002
    Hi all,
    I'm having a problem with the queryByRect function y PHP/Mapscript. My
code works fine with the queryByPoint, but if I try to use the queryByRect
it doesn't return any record. Here is a snippet of my code to do the search:
    dl('php_mapscript.so');
    $map = ms_newMapObj(_DATAPATH._GENMAPFILE);
    //This function change the status to 1 on the layers
ActivaCapas('Servicios+Comercios+Construccion+Industria+Agrupaciones+Resto+P
oblac',$map);
    $imgbox = str_replace(' ','+',$imgbox);
    $arrimgbox = explode('+',$imgbox);
    echo $imgbox.'<br>';
    $ext = str_replace(' ','+',$ext);
    $arrext = explode('+',$ext);
    echo $ext.'<br>';
    //Pix2Geo fron Gmap
    $minx = Pix2Geo($arrimgbox[0],0,$imWidth,$arrext[0],$arrext[2],0);
    $miny = Pix2Geo($arrimgbox[1],0,$imHeight,$arrext[1],$arrext[3],1);
    $maxx = Pix2Geo($arrimgbox[2],0,$imWidth,$arrext[0],$arrext[2],0);
    $maxy = Pix2Geo($arrimgbox[3],0,$imHeight,$arrext[1],$arrext[3],1);
    $rect = ms_newrectobj();
    $rect->set('minx',$minx);
    $rect->set('miny',$miny);
    $rect->set('maxx',$maxx);
    $rect->set('maxy',$maxy);
    //This query don't return any result
    @$map->queryByRect($rect);
    $resultado = array();
    for($i = 0;$i < $map->numlayers; $i++)
      $lyObj = $map->getLayer($i);
      if($lyObj->status == 1)
        $numResults = $lyObj->getNumResults();
        echo $lyObj->name.'-->'.$lyObj->status.'-->'.$numResults.'<br>';
        if($numResults == 0)
            continue;
        $lyObj->open($map->shapepath);
        //Nombre de los campos de los que se sacan los datos
        $selTables = $lyObj->getMetaData("DESCRIPTION");
        $selTitulo = $lyObj->getMetaData("TITLE");
        $selFields = explode(" ", $lyObj->getMetaData("RESULT_FIELDS"));
        $res = '';
        for($j = 0;$j < $numResults;$j++)
          $oRes = $lyObj->getResult($j);
          $oShape = $lyObj->getShape($oRes->tileindex,$oRes->shapeindex);
          //Concatenamos los resultados
          $res = $res.'|'.$oShape->values[$selFields[0]];
        $lyObj->close();
        $key = $selTables.'|'.$selTitulo;
        echo $key.'-->';
        echo $res.'<br>';
        $resultado[$key] = $res;
    return $resultado;
Is there any problem with the code or is the PHP/Mapscript version?, I use
the following Mapscript and Mapserver versions:
MapScript Version ($Revision: 1.104 $ $Date: 2002/04/24 20:37:32 $)
MapServer version 3.6.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
and PHP 4.2.1 in a Debian Linux.
Thanks in advance.
Regards.
Pedro A. Carrasco Ponce
IVER Sistemas de Información Geográfica
Dpto. Técnico
C/Salamanca, 50
46005 Valencia
Telf: +34 96 316 34 00
Fax: +34 96 316 2716
mail : pcarrasco at iver.es
web : http://www.iver.es
