[mapserver-users] proj4 and path configuration
Cedric BERNIER
cedric.bernier at thales-is.com
Mon Jul 8 04:45:50 EDT 2002
you're right I've remove the old one , and now it works ! thanks
Daniel Morissette a écrit :
> Cedric BERNIER wrote:
> > but now when I run mapserv I have another internal error displayed on my browser : error while loading shared libraries :/usr/libwwwappp.so.0 : undefined symbol: HTZlib_inflate
> > I've re-installed zlib and w3c with --with-zlib option but the error still remains....
> You may get this if you have 2 copies of w3c-libwww on your system: one
> under /usr/lib that came as an RPM (or with the OS), and one that you
> recompiled yourself and that got installed /usr/local/lib ... the
> solution is to remove the copy under /usr/lib. If your old wc3-libwww
> came as a RPM, then use 'rpm -e ...' to remove it to make sure that you
> delete all files related to the RPM version of the library.
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
Type: text/x-vcard
Desc: Carte pour Cedric BERNIER
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020708/0d17e654/cedric.bernier.vcf
