[mapserver-users] proj4 and path configuration
Daniel Morissette
morissette at dmsolutions.ca
Fri Jul 5 14:24:38 EDT 2002
Cedric BERNIER wrote:
> but now when I run mapserv I have another internal error displayed on my browser : error while loading shared libraries :/usr/libwwwappp.so.0 : undefined symbol: HTZlib_inflate
> I've re-installed zlib and w3c with --with-zlib option but the error still remains....
You may get this if you have 2 copies of w3c-libwww on your system: one
under /usr/lib that came as an RPM (or with the OS), and one that you
recompiled yourself and that got installed /usr/local/lib ... the
solution is to remove the copy under /usr/lib. If your old wc3-libwww
came as a RPM, then use 'rpm -e ...' to remove it to make sure that you
delete all files related to the RPM version of the library.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
