[mapserver-users] proj4 and path configuration
Cedric BERNIER cedric.bernier at thales-is.com
Wed Jul 3 10:12:21 EDT 2002
thanks it seems good,
but now when I run mapserv I have another internal error displayed on my browser : error while loading shared libraries :/usr/libwwwappp.so.0 : undefined symbol: HTZlib_inflate
I've re-installed zlib and w3c with --with-zlib option but the error still remains....
Lowell Filak a écrit :
> If you are on Linux simply make sure that /etc/ld.so.conf contains /usr/local/lib (which it probably does) and then run '/sbin/ldconfig' as root then restart the httpd daemon.
> The proj.4 install usually adds /usr/local/lib to the config file but the new path is not included in the library config until after ldconfig is run.
> Lowell F.
> P.S. Anyone out there have an estimate on how long the wiki will be down?
> The following message was sent by Cedric BERNIER <cedric.bernier at thales-is.com> on Wed, 03 Jul 2002 12:34:26 +0200.
> > Hi all!
> > I've decided to use the --with-proj option in config the re-install mapserv.
> > I have a problem when I start mapserv .
> > my navigator displays an internal error.
> > the /var/log/httpd/error_log says :
> > mapserv:error while loading libraries:libproj.so.0 cannot open shared  object
> > file : No such file or directory.
> > certainly a PATH misconfiguration ...
> > this lib is installed in my /usr/local/lib.
> > Is there anything to configure like an environment variable or something like
> > that ?
> > Thanks for your help.
> > Have a nice independance day.
> > CB.
Type: text/x-vcard
Desc: Carte pour Cedric BERNIER
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020703/e204b591/cedric.bernier.vcf
