[mapserver-users] proj4 and path configuration
Lowell Filak
lfilak at medinaco.org
Wed Jul 3 09:39:54 EDT 2002
If you are on Linux simply make sure that /etc/ld.so.conf contains /usr/local/lib (which it probably does) and then run '/sbin/ldconfig' as root then restart the httpd daemon.
The proj.4 install usually adds /usr/local/lib to the config file but the new path is not included in the library config until after ldconfig is run.
Lowell F.
P.S. Anyone out there have an estimate on how long the wiki will be down?
The following message was sent by Cedric BERNIER <cedric.bernier at thales-is.com> on Wed, 03 Jul 2002 12:34:26 +0200.
> Hi all!
> I've decided to use the --with-proj option in config the re-install mapserv.
> I have a problem when I start mapserv .
> my navigator displays an internal error.
> the /var/log/httpd/error_log says :
> mapserv:error while loading libraries:libproj.so.0 cannot open shared object
> file : No such file or directory.
> certainly a PATH misconfiguration ...
> this lib is installed in my /usr/local/lib.
> Is there anything to configure like an environment variable or something like
> that ?
> Thanks for your help.
> Have a nice independance day.
> CB.
