[mapserver-users] Can't figure out queries with Mapscript.
Thomas Haechler
thaechl at geo.unizh.ch
Tue Jul 9 02:52:35 EDT 2002
hi chip and list,
I think what ben wants to know (and I couldn't figure it out eighter),
is how to use the processquerytemplate method, i.e. process a template
and replace some tags in it with query results, or link external info.
Steve Lime recently answered this question for the cgi version
(http://mapserver.gis.umn.edu/wilma/mapserver-users/0206/msg00377.html),
but I don't know how it works with mapscript.
any ideas?
thanks,
Thomy
"Hankley, Chip" wrote:
> Ben...
> There's probably a number of ways to do this, but here's how I do it (see
> below). There's a Mapfile component, and a mapscript component. FWIW, this
> is essentially exactly the way it's done in the GMAP demo.
> Cheers!
> Chip
> ...in the mapfile, this would be the layer definition for the layer I want
> to query:
> LAYER
> NAME "DePere_Parcels"
> METADATA
> "DESCRIPTION" "PARCEL_INFO"
> "RESULT_FIELDS" "PARCEL_NUM AREA"
> # These are the two fields (PARCEL_NUM and
> # AREA) that I want to return
> END
> DATA parcels
> STATUS DEFAULT
> #minscale 5000
> TYPE polygon
> CLASS
> TEMPLATE "ttt_query.html"
> Name Parcels
> END # CLASS
> END # LAYER
> ... in the PHP code, I have a function that handles the query...
> function query_map($map, $real_pts) {
> //$map is the Map Object
> //$real_pts is an array with two members:
> // $real_pts[0] x-coordinate in real world terms of the user click
> // $real_pts[1] y-coordinate in real world terms of the user click
> //NOTE that this function is set up to query only ONE layer, and return
> // the first HIT from a query... so it wouldn't handle multiple layers
> // or return results from numerous objects, although it could easily be
> // modified to do both.
> $click_pt = ms_newPointObj();
> $click_pt->setXY($real_pts[0], $real_pts[1]);
> @$map->queryByPoint($click_pt, MS_SINGLE, -1);
> $Layer = $map->GetLayerByName("DePere_Parcels");
> $count_results = $Layer->getNumResults();
> if ($count_results > 0) {
> $Layer->open($map->shapepath);
> $selFields = explode(" ", $Layer->getMetaData("RESULT_FIELDS"));
> //Take the first record returned, you could modify this to
> // loop through a bunch of returned records
> $oRes = $Layer->getResult(0);
> $oShape = $Layer->getShape($oRes->tileindex,$oRes->shapeindex);
> //Save the bounding box to an array
> $aResBoundBox = array($oShape->bounds->minx, $oShape->bounds->miny,
> $oShape->bounds->maxx, $oShape->bounds->maxy);
> //Retrieve the PIN into a variable
> $PIN = $oShape->values[PARCEL_NUM];
> $prcAREA = $oShape->values[AREA];
> $oShape->free();
> $query_result = array($PIN, $prcAREA);
> $return $query_result;
THOMAS HAECHLER
Geographic Information Systems Division
Institute of Geography
University of Zurich
Switzerland
thomas.haechler at geo.unizh.ch
