[mapserver-users] GDAL not working perhaps
Ed McNierney ed at topozone.com
Wed Jul 10 11:53:08 EDT 2002
Isai -
The EXTENTS are the bounding box of the output map image, in the native units of the output image projection.  For example, if the output projection is UTM Zone 19 North, the EXTENTS are in UTM northing and easting meters.  If the output projection is geographic, the EXTENTS are in decimal degrees.
	- Ed
-----Original Message-----
From: Isai Michel [mailto:isaimichel at hotmail.com]
Sent: Wednesday, July 10, 2002 11:49 AM
To: Ed McNierney; Rich at GreenwoodMap.com
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [mapserver-users] GDAL not working perhaps
That would depend on what the definition of the map file EXTENTS variable
is.  I have previously tried manipulating the EXTENTS and found that certain
variations cause the image to disappear.
If you could give me a better definition of EXTENTS or how exactly EXTENTS
work, then that might cause the images (which I guess theorectically should
be there) to come back into view.
Thank you.
Respectfully:
IML
_________________________________________________________________
Chat with friends online, try MSN Messenger: http://messenger.msn.com
