[mapserver-users] question about GMAP demo
E Perik erwin at perik.nu
Wed Jul 10 16:26:49 EDT 2002
Hi Ivan,
i think when you use it like below, it should work.
  METADATA
   "DESCRIPTION"   "Assi Stradali"
   "RESULT_FIELDS" "NOMEVIA COD_VIA LENGTH" # <--changed
  END
The file: TEMPLATE "ttt_query.html" needs to be in there if you want to
query.
The file 'ttt_query.html' should contain all your Micro$oft licenses
(case sensitive).
No,... kidding,... it does not have to exist at all. You can also use
TEMPLATE "foo"
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of Ivan
Paoluzzi
Sent: woensdag 10 juli 2002 20:25
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] question about GMAP demo
I have install GMAP demo and it works very well!
But I have a question, this is my layer:
LAYER
  NAME assist
  METADATA
   "RESULT_FIELDS" "NOMEVIA" "COD_VIA" "LENGTH"
  END
  TYPE LINE
  STATUS ON
  DATA assist
  TOLERANCE 8
  LABELITEM nomevia
  LABELMAXSCALE 20000
    CLASS
      NAME "Assi Stradali"
	COLOR 0 0 100
        LABEL
          COLOR 255 0 0
	    FONT fritqat
	    TYPE TRUETYPE
	    SIZE 8
            ANTIALIAS TRUE
	    POSITION AUTO
            ANGLE AUTO
            MINFEATURESIZE 40
            MINDISTANCE 100
	    PARTIALS FALSE
	    BUFFER 3
	  END  #LABEL
    END  # CLASS
  TOLERANCE 5
END  # LAYER
Why it doesn't work?
I don't understand the line TEMPLATE "ttt_query.html".
I don't find this template in application files, where is it?
Thanks.
_________________________________________________________________
Chiacchiera con gli amici online, prova MSN Messenger:
http://messenger.msn.it
