[mapserver-users] question about GMAP demo
Ivan Paoluzzi
tesimap at hotmail.com
Wed Jul 10 19:52:34 EDT 2002
I have changed the line "RESULT_FIELDS" "NOMEVIA" "COD_VIA" "LENGTH"
in "RESULT_FIELDS" "NOMEVIA COD_VIA LENGTH" but I haven't still result when
I do a query. This is my problem. Any idea?
Regards
Ivan
>From: Yewondwossen Assefa <assefa at dmsolutions.ca>
>To: Ivan Paoluzzi <tesimap at hotmail.com>
>CC: mapserver-users at lists.gis.umn.edu
>Subject: Re: [mapserver-users] question about GMAP demo
>Date: Wed, 10 Jul 2002 16:23:16 -0400
>Hi There,
> What is wrong exactly ? What kind of errors do you recieve ? You should
>give more details on the error or problem.
>Checking your layer here are the comments I have :
> - The template entry is necessary to do queries, the value is not
>critical here.
> - One error that I see is the way you defined the RESULT_FIELDS" tag.
>It should be define like this :
> The GMap demo application assumes to find the DB fields names with a
>space between the names.
>Best Regards,
>Ivan Paoluzzi wrote:
> > Hi,
> > I have install GMAP demo and it works very well!
> > But I have a question, this is my layer:
> > LAYER
> > NAME assist
> > METADATA
> > "DESCRIPTION" "Assi Stradali"
> > END
> > TYPE LINE
> > STATUS ON
> > DATA assist
> > TOLERANCE 8
> > LABELITEM nomevia
> > LABELMAXSCALE 20000
> > CLASS
> > NAME "Assi Stradali"
> > TEMPLATE "ttt_query.html"
> > COLOR 0 0 100
> > LABEL
> > COLOR 255 0 0
> > FONT fritqat
> > TYPE TRUETYPE
> > SIZE 8
> > ANTIALIAS TRUE
> > POSITION AUTO
> > ANGLE AUTO
> > MINFEATURESIZE 40
> > MINDISTANCE 100
> > PARTIALS FALSE
> > BUFFER 3
> > END #LABEL
> > END # CLASS
> > TOLERANCE 5
> > END # LAYER
> > Why it doesn't work?
> > I don't understand the line TEMPLATE "ttt_query.html".
> > I don't find this template in application files, where is it?
> > Thanks.
> > _________________________________________________________________
> > Chiacchiera con gli amici online, prova MSN Messenger:
> > http://messenger.msn.it
>Assefa Yewondwossen
>Software Analyst
>Email: assefa at dmsolutions.ca
>http://www.dmsolutions.ca/
>Phone: (613) 565-5056 (ext 14)
>Fax: (613) 565-0925
Specisci e ricevi le tue email Hotmail dal tuo cellulare con:
http://mobile.msn.it
