[mapserver-users] Python Mapscript MS 3.6.1
Norman Vine
nhv at cape.com
Sun Jul 14 07:34:49 EDT 2002
Vinko Vrsalovic writes:
>On Thu, Jul 11, 2002 at 08:15:36AM -0400, Frank Warmerdam wrote:
>> I have also committed Norman Vine's setup.py script to CVS though I find
it
>> takes quite a bit of hand editing to build and install for different sets
of
>> build options. It would be nice for it to pick up more information about
the
>> MapServer build from the configure output at some point, but that isn't
>> high on my priority list.
>Yes, i totally agree, i may give it a try
the attached setup.py works for me with Cygwin picking up the
'configuration' automagically :-)
Note my use of the 'extra_objects' field < see # comment in script >
Cheers
Norman
#! /usr/bin/env python
# Distutils setup for UMN Mapserver mapscript v.3.7
# Norman Vine 7/13/2002
# Should work as is on 'Unix' like systems
# To Install
# build mapserver
# Copy this file to $MAPSERVER_SRC / mapscript / python
# invoke as ./setup.py install
# should work on any python version with Distutils
from distutils.core import setup, Extension
from distutils.spawn import spawn
from distutils.dir_util import mkpath
from distutils.file_util import copy_file
from distutils.sysconfig import parse_makefile,expand_makefile_vars
from string import split
import os
from os import path
noisy=1
swig_cmd = ["swig",
"-python",
"-shadow",
# "-opt",
"-DPYTHON",
"-DUSE_GD_PNG",
"-DUSE_GD_JPEG",
"-module",
"mapscript",
"-o",
"./mapscript_wrap.c",
"../mapscript.i" ]
spawn(swig_cmd, verbose=noisy)
# make package directory and package __init__ script
mkpath("mapscript")
init_file=open(path.join("mapscript","__init__.py"),"w")
init_file.write("from mapscript import *\n")
init_file.close()
copy_file("mapscript.py", path.join("mapscript","mapscript.py"), verbose=noisy)
# change to reflect the gd version you are using
gd_dir="gd-1.8.4"
ms_dir=path.join("..","..")
local_dir="/usr/local"
# parse mapserver Makefile using distutils to determine configured libs
DICT = parse_makefile(path.join(ms_dir,"Makefile"))
tmp = split(DICT[expand_makefile_vars("LDFLAGS",DICT)])
lib_list = []
for lib in tmp:
if lib[1:2] == 'l':
if lib == '-lmap':
continue
lib_list.append(lib[2:])
setup (# Distribution meta-data
name = "pymapscript",
version = "3.7",
description = "pre release",
author = "Steve Lime",
author_email = "steve.lime at dnr.state.mn.us",
url = "http://mapserver.gis.umn.edu/",
# Description of the modules and packages in the distribution
packages = ['mapscript'],
ext_modules =
[Extension('mapscriptc', ['mapscript_wrap.c'],
define_macros=[('TIFF_STATIC',None),('JPEG_STATIC',None),('ZLIB_STATIC',None),
('IGNORE_MISSING_DATA',None),('USE_EPPL',None),('USE_PROJ',None),('USE_PROJ_API_H',None),
('USE_WMS',None),('USE_TIFF',None),('USE_JPEG',None),('USE_GD_PNG',None),('USE_GD_JPEG',None),
('USE_GD_WBMP',None),('USE_GDAL',None),('USE_POSTGIS',None)],
include_dirs=[ms_dir,
# path.join(ms_dir,gd_dir),
# path.join(ms_dir,"gdft"),
# path.join(local_dir,'include/freetype'),
path.join(local_dir,'include')
library_dirs=[ms_dir,
'/lib',
path.join(local_dir,'lib')],
# link order matters with Cygwin
extra_objects=[path.join(ms_dir,'libmap.a'),'/usr/local/lib/ogr.a'],
libraries = lib_list, ), ]
